Gordo 0 Report post Posted August 26, 2016 Chris, You just burned some images into my tired brain, that I really didn't want....... Share this post Link to post Share on other sites
huckersideways 0 Report post Posted August 26, 2016 Penance well paid for some of the dick shit you've put up no doubt. Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 26, 2016 Would bang 10/10 Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 26, 2016 Found more info on the immob chip. It really is a simple procedure I guess just needs skillful hands Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 26, 2016 So thus far I believe this is my plan. Flame at will because I'm sure I'm wrong and stupid and a disgrace to all things jz.... Now then, using 1j motor harness drop motor in, 1j harness to 1j ecu. Then I need 01 body plugs that plug into the ecu, and then I need to take the body plugs off the 2j harness put them on the 1j harness so I can plug that into those connectors next to the ecu. as long as all goes according to plan on the immob shit then this should work? I'm thinking. Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 26, 2016 Found more info on the immob chip. It really is a simple procedure I guess just needs skillful hands How much is it worth to you to have it done ? Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 26, 2016 Not a lot I know it's easy Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 26, 2016 That looks like it's pretty simple to do. Any computer repair/cell phone repair place should be able to hook you up. Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 26, 2016 Man it'd be really cool to try to get a manual ecu for one of those things. I live in obd2 regulated county. Shit wouldn't let me have that and I'm not a fan of illegal stickers. If I didn't, I'd have had a jzx100 powered one a long time ago Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 27, 2016 A manual 171/110 ecu? To do what not show any codes? And yea that's what iv been told but I have to make sure I can verify the right chip and placement to tell them. And I also Got my thinking wrong before. I was thinking I need the 01 plugs that go from body to ecu but if the 2j harness plugs in okay then those should too? So I have everything I need just need to swap immobs and verify/ repin Share this post Link to post Share on other sites
NAC 0 Report post Posted August 27, 2016 What do they regulate in "an obd2 regulated county"? My jzx100 is not OBD2... Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 27, 2016 Has to pass obd2 emissions, which would be plug and scan for obd2 monitor ready status bs Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 27, 2016 And not for the no codes thing, but for the more aggressive tune. Or get that Russians auto sim box, bet it'd work Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 27, 2016 Ahh okay I see yea that would be cool, did they ever make factory manual 110s? So even with everything plug and play and what not the obd2 won't ever read normal? I can get around emissions easy enough we have a few county's 50 miles south that are free and I just use buddies address out there. Would be cool if it could pas though Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 27, 2016 nah no way without running stock ecu, which is gonna run like shit compared to stock gte ecu Share this post Link to post Share on other sites
Okidriftjr 0 Report post Posted August 28, 2016 There are a few stand alones out on the market that offer obd2 can buss features. Not sure if that would solve the problem kyle, but it's a possible option. Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 28, 2016 Do those standalones run monitor systems for each federally mandated system up to a certain number of said systems? Either way they're not fed approved so I'm sure it's illegal if getting caught. Really the biggest issue is it'd always have an ocv code that I can think of off the top of my head Share this post Link to post Share on other sites
Okidriftjr 0 Report post Posted August 28, 2016 No clue. I have never looked to see what exact information is gathered at an emissions test facility. Up here, at our DEQ stations, if your car doesn't have a CEL, you will pass the tests. I have literally cleared a code in the parking lot before running a car through to pass. Share this post Link to post Share on other sites
DiscoShit 0 Report post Posted August 29, 2016 In ny, the cars ecu needs to check up on "set monitors", that include things like. Catalytic, 02 sensor. 02 sensor heater, evap and a few other things. The newer the car, the more monitors it has avaliable. You can no just clear the cel. Share this post Link to post Share on other sites
ChriSOL 0 Report post Posted August 29, 2016 new cars suck. you can fit a ton of processing power into a computer the size of a credit card now though. if someone had the basic skill and patience to translate that shit and create a total sim program that allows you to run the engine however you want and still have full function from your accessories, gauges etc... and be able to pass a sniffer you would probably get killed by the government and have your shit totally disappeared like the dude that invented the 100+mpg carburetor. Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 29, 2016 This got me interested in my laws here in Denver I knew they changed, but look I'm still good in the 02 luckily and anything older. Share this post Link to post Share on other sites
TheDonBastard 0 Report post Posted August 29, 2016 If Colorado can just fucking chill and leave the rules alone for awhile. I doubt il own a car newer then 05 and if so I doubt I'd mod it enough for it to matter. There making it harder to flip cars and shit too which is my bread and butter. Share this post Link to post Share on other sites
Gordo 0 Report post Posted August 29, 2016 if someone had the basic skill and patience to translate that shit and create a total sim program that allows you to run the engine however you want and still have full function from your accessories, gauges etc... and be able to pass a sniffer you would probably get killed by the government and have your shit totally disappeared like the dude that invented the 100+mpg carburetor. If you buy a GM car, they don't sell you the ECU, it stays in their ownership, and if you dick with it, you get what ? Sued? Have it confiscated ? A wet team sent out to cap your ass ? And Chris, stop believing in urban myths, or I'll sent chupacabra up your way. Share this post Link to post Share on other sites
Kyle 0 Report post Posted August 29, 2016 Our shit is like disco's. You clear the code, the monitor won't be ready, it won't pass. Monitors must be set. You get a pass for like 1 on newer cars, and 2 on early obd2 cars. Share this post Link to post Share on other sites
Okidriftjr 0 Report post Posted August 29, 2016 That's fucked up. I hate obd2 emissions bull shit regs. Guy was able to get his 2j in his x7 to pass but putting on a fresh cat and dialed his safc to run the car a little lean. He said the inspector said the car passed the sniffer better than if the car was new. I don't believe he told them it was a swapped engine...... Share this post Link to post Share on other sites
