shlammed 0 Report post Posted May 26, 2016 Car is getting a bit hot, it doesn't have a fan shroud or pre-heat exchanger ducting right now but I've got sheet aluminum to do the ducting this week. In an x8 with 1j and clutch fan/7m blades is there a stock fan shroud that works? I would prefer not to have to fab one up out of sheet or go electric - engine fans work great with a shroud. Share this post Link to post Share on other sites
shlammed 0 Report post Posted May 26, 2016 Cressida by HellaFab Fabrication, on Flickr Share this post Link to post Share on other sites
Gordo 0 Report post Posted May 26, 2016 I'd dump the stock radiator..... I had went to a Koyo meant for an IS300. Whoremouth has it now. Somewhere up here is a thread on how I mounted it. I am going to my custom Fluidine 2" core crossflow now. But you can chink out with some pos from chinaBay if you like. Share this post Link to post Share on other sites
shlammed 0 Report post Posted May 26, 2016 I don't think the car would have any issues with a fan shroud and ducting. ducting I can do. fan shroud I can do too, but if the stock one fits I can go to the wrecker and pick it up for free and save a few hours. I will be doing a rad at some point, but I want to drive the car now. im sure being a 26 year old machine im going to have to change a few parts as I drive it. Share this post Link to post Share on other sites
Gordo 0 Report post Posted May 26, 2016 Ran this with a stock radiator, just wasn't up to 12:1 compression, and 8500 rpm. The reason I went to the IS radiator. Ran the Koyo, with the same fan set-up with Zero issues. Share this post Link to post Share on other sites
ChriSOL 0 Report post Posted May 26, 2016 dear b-hole OP: my setup consists of a 1uz fan clutch - unmodified, a 7M fan, a stock radiator and thermostat and no fan shroud. i live in TX. ambient temps in the summer are around 110°F (+/- 10°) and i have never seen my gauge creep past operating range after long hauls or stop-and-go traffic. this is on a jzx81 JZ-GTE with stock twins, fwiw. Share this post Link to post Share on other sites
shlammed 0 Report post Posted May 26, 2016 whats stock operating range? the car is happy at 86celcius most days, goes up to 93celcius on hot days and when I brought it home it was 32celcius ambient and it got up to 98celcius on the highway. conversion: 86C=186F 93C=200F 98C=210F 200 isn't bad, but that's just daily driving. If I was doing any kind of event it could get bad. 210 is pretty hot, and that was cruising at 120km/h (75mph). no real boosting, just cruising steady state. If I had a stock temp guage, it would probably be stuck in the middle the whole time... but the digital dash shows me real temps. another data point, I recently put a 0.9 bar stock rad cap back on. the 1.5bar rad cap pictured above was causing minor seeping from the rad hoses. Temps haven't changed since I changed that though. This is why Im registering/driving the car for a while before I get too invested in mods. Share this post Link to post Share on other sites
Rue 0 Report post Posted May 26, 2016 You're still not figuring shit out... Share this post Link to post Share on other sites
rkc14 0 Report post Posted May 27, 2016 shlammed, I have the exact same fans that Gordo has pictured if you are interested in running that set up. Share this post Link to post Share on other sites
slapsticksammy 0 Report post Posted May 27, 2016 I ran into the issue where the stock fan shroud and jz clutch fan wouldn't work. So I went and bought a fan shroud for a Cheville (or some merica car) that was about the right size. The shroud had two slim 1200 cfm fan which I mounted to a fan controller. Normal days I run at 89-92 C which is about right. But the other day with the AC on it crept up to 98-100 C, which from what I gather is still not too hot. The problem is that my engine is so close to the fans I don't have space to evacuate the air. So I am now working to shroud the air and force more of it through the radiator. I was also told to shim the hood so that it has space around the cowl to evacuate the hot air. Or if you want to go wild, cut the hood and add a drop vent. Share this post Link to post Share on other sites
Gordo 0 Report post Posted May 27, 2016 Forum Bull Shit on the raising the rear of the hood. At any speed over 45mph, that is a high pressure area due the the windshield. If anything, that will hurt cooling. Why do you think so many cars in the '70s had 'cowl induction'. It is a good place to pick up high pressure air to feed a a carb. Find the under tray, maybe even save some pennies, and buy a drop vent. Drive over to my place, and buy the FRP drop vent I brought in from Japan. The area on the hood just back from the radiator is a low pressure area. Share this post Link to post Share on other sites
slapsticksammy 0 Report post Posted May 27, 2016 Gordo I agree with you at high speeds it will hurt cooling. What's er this frp drop vent you have? You wouldn't have an extra jzx81 hood lying around would you? Share this post Link to post Share on other sites
ChriSOL 0 Report post Posted May 27, 2016 ^ it also looks fucking gay, identifies the car's owner as a know-nothing shitstain wannabe, died where it deserved to in 2010. cant wait for hood propping to make a "nostalgic" comeback. Share this post Link to post Share on other sites
shlammed 0 Report post Posted May 27, 2016 I have a pretty cool hood vent already guys. And a vented grille Matt Cressida by HellaFab Fabrication, on Flickr The under tray is the ducting I'm talking about. Share this post Link to post Share on other sites
Gordo 0 Report post Posted May 27, 2016 Slapstick, I have the Missile vent that I brought out of Japan, before finding a way to actually get a complete hood from there. No spare hood until I take my stock one off, and mount the 'glass one, but Kyle may have one. Share this post Link to post Share on other sites
huckersideways 0 Report post Posted May 27, 2016 How much shipped to. Uh. Not Canada. Share this post Link to post Share on other sites
Gordo 0 Report post Posted May 27, 2016 Pretty sure it's spoken for..... But doesn't the guy who took over mitch's fiberglass wet dream make one simular, for about $160 ? Tried to buy one from him, but he never replied, until I just ordered this out of Japan. Share this post Link to post Share on other sites
huckersideways 0 Report post Posted May 27, 2016 I don't really care that much. Might make my own out of metal. Or just take the hood off because that's what the cool kids are doing. And people wonder why the pigs are salvage title ing cars left right and centre. Share this post Link to post Share on other sites
ChriSOL 0 Report post Posted May 28, 2016 ^ hoods off eh? funny you mention that. Share this post Link to post Share on other sites
