cityslicker 0 Report post Posted September 5, 2015 Hey folks, I'm looking at running a 1JZGTE in my x7 Cressida with the Cressi Koyo radiator. I'm now looking for a suitable fan setup for the engine running increased boost using the koyo radiator. Size on the radiator is roughly 15"x30" and I will be running a Derale wiring kit to run them off temp, but unsure what the recommended CFM output range y'all suggest. Obviously I plan on running as much air through the rad as possible, I have a bad habit of buying cars that over-heat and want to save myself from that headache. What I've found so far: 2 x 12" electric fans off eBay, push around max 4000 CFM OR run a single 16" pushing around 3000 CFM Anyone found an alternative, or swear by running a shroud on their rad? Thanks for sharing your experiences! Share this post Link to post Share on other sites
Gordo 0 Report post Posted September 5, 2015 Fuck off, and sell the fucking car........ You can't even handle doing your intro corretly. We ask people to do an intro in order to determine if you are qualified, not to know anything about you. You are not, because you failed to follow the rules, just like you will fail to follow what we may tell you, even if we were to hold your hand. (we don't do that here) Share this post Link to post Share on other sites
Gibbs 0 Report post Posted September 5, 2015 god damn it your a :Cressi: fag as well get the fuck out of here Share this post Link to post Share on other sites
slapsticksammy 0 Report post Posted September 5, 2015 1jz's are junk. you need to run the modular ford 4.6 v8. Share this post Link to post Share on other sites
cityslicker 0 Report post Posted September 9, 2015 Fuck off, and sell the fucking car........ You can't even handle doing your intro corretly. We ask people to do an intro in order to determine if you are qualified, not to know anything about you. You are not, because you failed to follow the rules, just like you will fail to follow what we may tell you, even if we were to hold your hand. (we don't do that here) This is true. I should've read the rules prior to posting. Intro went up too late, that's on me. Share this post Link to post Share on other sites
