tougekid1
Working Speedo.
I dug up some part numbers and I think I have the parts I need to make the 92 analog speedo work. This will hopefully get me from the R154 to the stock Cressida cable. Can anyone confirm?
Cable part number: 83710-14800
The 90* from the auto part number: 83770-30070.
I used the mk3 supra turbo extension. Pretty sure the stock cable works with some maneuvering
is the a340 in the 91+ different? using the elbow and cable from supra here, pulled from junkyard on the cheap.
Did i miss something?
I had no idea the r154 had a cable speedo output..
Or am i just dumb and confused
I believe there are 2 different outputs for the r154 depending on year or application IIRC. One is electric the other is gear.
Yea the top part number is the MK3 cable extension. Ok cool Im on the right path. Thank you for the input.
The speedo outputs interchange (elec. vs. mechanical).
And you almost need the short extension cable from the Supra, as the speedo drive is on the opposite side from the auto to 5-speed. (well it is on the W58).
i used w58 elbow and cable. i think. i KNOW all my parts came from auto x8 and w58 mkiii.
I just kept working at finding the right path and used the stock cressida cable on my JZA70 R154 tranny.
