NAC
SSR Welded 3pc
Anyone know if you can split these and keep the lip/barrel in useable condition? might trade my varrstoens for a set, but never dealt with welded 3pc...
You can pull the centers.
I use a hot air gun to get the barrels warm enough so the centers drop out, and again so they drop on, but you need some alignment pins, or you pay hell to get the bolt holes centered.
welded 3pc can mean a lot of things. could be welded inner and outer and a removable face. could be all welded together.
could be like the 2pc meisters, which are just fully welded.
what wheels are they?
im not quite sure what gordo is referring to with heat and re centering it. but, there's a lot of different types of wheels and how they're constructed.
if it is a welded 3pc, like was 3pc's then welded into one, i think the USA is your only option? I don't know anyone locally or on the Mainland that splits wheels. You could TRY Green's but I don't think they do. If you call, talk to Brad, not his dad. Brad is more realistic, his dad says no to everything that isn't easy.
Green's splits wheels.
