hantavirusx8
Project Hantavirus
TRD 2 way is in and amazing. I haven't heard a noise from it. Super smooth and predictable lockup.
received_1458836904150754_zpstmvaopbn.jp
I forgot to mention I used an SW20 MR2 booster to clear the FFIM. Straight bolt in.
Also got a trailer so I can tow to events! Picked it up in rough shape for $700. Sanded down and painted with POR15, sanded the deck and resealed it, greased wheel bearings, fixed wiring, new tires, new lights, and new jack. Now I'm just counting down the days until PARC and hoping it's dry and not a muddy shitshow
16729200_1488761481158759_59053451150320
Looks good. Have you tried that brake booster yet? Interested to know if it gives the same amount of assistance.
Yeah I've been driving with it for months. It's hard to say but it feels like it has maybe 70% of stock assist. The brakes feel more "direct" and still have plenty of power to lock up if needed
Killin it
I saw a couple people were using the 2UZ Tundra 130A alternator so I decided to give it a shot. I grabbed an 04 Sequoia alt which is a 150A, hairpin stator. Cut one mount down, cut another mount off, change the plug and you're good to go. Night and day difference from the stock alt. Maintains 14V at idle with everything on.
18052924_1562586360442937_601464806_n_zp
18083666_1562586307109609_1624192492_o_z
Aligned today
18110243_1562586150442958_244082217_o%20
I might go to PARC on the 30th, anyone going?
Got it from B&R auto wrecking for $71. Pulley is the same. Uses a common toyota or honda square alt plug. I slipped it on over the bottom stud and marked the top mount where it needed to be trimmed and cut it down slowly until it aligned with the other pulleys with a straight edge. Apparently hairpin stator alts are a newer design that run cooler and charge better at idle
I can load and clamp the JZ, JZ vvti and sequoia alts if you guys are really interested but the sequoia alt is significantly stronger from what I've seen
Downsized to a BW s257sxe. Went with a 1.0 twin scroll turbine housing hoping to still make 500whp with good response. No dyno yet but it doesn't feel like it really lost any power. Effortlessly pulls 3rd gear around the back of PARC with 3.91's. 17 psi at 3500rpm
Next mods are adjustable rear arms and a cage.
nice turbo!
I went with the .83 twin housing hoping for quick response hopefully it dosent choke.
that last picture looks bitchen.
WOW. I guess you are our one good new member for 2015. Welcome.
Got a Link storm g4+ ecu. I've installed and tuned three now and they're really versatile, capable, and easy to use. Got an S360 in a trade and put in Precision 680cc injectors. Switched to a GM 3 bar map after this pic. No dyno yet but it feels better than ever and loves turning 8000.
Setup rally style antilag with the Link. Feeding the IACV from the intercooler pipe on liftoff. It's wild
Bimarco Grip seat. It's on the large side but it's pretty nice
Amazing :thumbsup:
Those equips were made for this car
Engine bay is sex!
What's the throttle cable set up?
