hantavirusx8
Project Hantavirus
Chris
He's using the iacv to add small amounts of air when the Link fires the injectors during decal.
So that billet wheel connected to your throttle cable sitting beside the throttle body.Thats 94 camry shit?
What are you running for a throttle body? Factory 2jz?
Nah it's an ebay 84mm throttle body with a 1j tps. I'll try to get some antilag vids soon. Maybe do a burnout or something.
Cool thanks for the info man!
tune my link g4 storm haha
Broke a ringland on number 6 after a wastegate spring mishap :( Car still ran fine but felt a little off. Bought a 2jzge vvti from the junkyard, shows up monday. Picked up gte pistons and rods, BC springs and retainers, and ACL rod bearings. Dropping the head off for a resurface and valve grind. Using an NA headgasket to maintain proper quench. Should be a ripper.
I literately have a ge vvti head with bc springs and retainers covered in WD-40 and wrapped to shit in my garage i could have sold to you... saving it for a rainy day..
still think you should stick to NA pistons.
the application is all wrong to begin with, i'm well aware that the lands are smaller.
Isn't the point of the ALS to help with bottom end power? high compression will help with that, and more so with vvti...
if you're going for cool points, by all means disregard anything i say.
Thanks.
Personally, I think anyone not running forged pistons is a woosy......especially in a boosted engine.
Junkyard JZ looked pretty nasty on the outside but amazing inside.
Got everything finished up. Runs great and picked up a bunch of low end power.
Nice! glad to see someone with motivation still
It's been a while, but I'm still driving the x8. I painted it Lambo Grey, built a new harness from scratch, and converted to E85. Currently making 542whp and a whopping 508 ft lbs at 18 psi.
great car. he's given me a ride along at spirit peaks and this thing shreds.
makes me want to make more power.
On 6/14/2019 at 3:32 PM, LUMBERZACK said:
Buy a 2J?
sure ill buy a 2jzge bottom end once i blow my 1j up.
