All Activity
This stream auto-updates
- Last week
it'd probably shrink or peel off with the heat. I'll end up getting them hydro dipped or painted and getting the weld valley cover
love it.
damn big sexy, you been crawling the arab sites for that storage console piece?
hey bro, i have your back. some dude flaked on the whole front deal i had so these usdm perfectly 👌🏻 are yours.
what would make the most sense in your scenario is to paint it black, get pre made vynil of the colours (im missing the orange lines) and then apply them. when not feeling it no more, its still black after you remove the vynil
I don't have the patience for that. I assumed it would have been cut vinyl, paint the base, lay out vinyl, paint, lay out vinyl, paint, lay out vinyl paint, etc etc etc for every layer. Hand cut sounds like a gigantic pain in the ass. Good on you.
Hks file? That's all paint my dude. I think I did green, purple then black then flake in clear then clear. I hand cut the tape to apply, staggered them...really should have looked more at the photo as I did it incorrect. I'm still happy with what I did but it could have been more fun and wild..but I like how simple it is. It really pops when I open the garage door so mission accomplished. I did a Jun coloured one for the civic, silver green and yellow in the same splash graphics. Richard Rabe has got to be the best at the hks livery painting though. I plan to do a zebra paint job on the 1uz covers. I'll see how that goes. Got a plan in mind for that already
where did you get the HKS file? is that just vinyl? kinda wanna do my valve covers like this--but also kinda just want something simple and get the Weld coil cover.
- Earlier
i took some time away from cars after the tents fell down on the cars. i have since sold what remains of the tents for $150 and am getting a quote from a guy who does metal enclosures. its been a few weeks so im not holding my breath he makes it any time soon. been busy being a dad and have little time for garage activities, however motivation was at an all time low as my garage was full of non sense and my cars kept needing maintenance and not "fun stuff." first thing was to sort the garage and shed at the same time so a lot of back and forth. shed is still a catch all but all items are useful still and what junk is in there is temporary. sold a bunch of stuff from in there and tidied up a bunch, put some tools in there for easier access. garage as of a couple days ago. sold the bike, put the boards in the shed after I sold the air scrubber and removed the motor from the lexus. this back corner is a bit of a mess with all the drawers. it was organized until i added this rather large sony Trinitron. i have been after one for a while for my old game systems and this was free, took nearly 3 months to get as they live on a remote island and only come to this island once a month. for whatever reason i had been hooked on these old style of Trinitron as it has a lot of inputs in the back and my uncle had one when i was younger and just always wanted one...seemed to pair perfectly with the sony playstation...nostalgia is a hell of a delusion. currently it is hooked up to my VHS and my old options are what get played in here. My house is too small to put it in the actual house, so here it is. House is 1085sq ft, she tiny, and it houses 2 adults, 1 baby and 2 cats. Supra hasnt had anything done to it since i started putting the engine bay back together months ago. I have oval tube on order and its back ordered but I have been messing about with the integra air box, got a new filter for it and ill come to a conclusion on that soon. Cressida has been put back on the road and I have been dailying it to see what new problems it has developed since sitting there since Oct 2020. First up was replace the very old battery as this was the last part of the puzzle for the poor start, currently it starts very good and strong. Steering has felt weird since driving it around, found a loose castor rod nut, and the diff is rather chattery (going to change that soon), and the brakes..brake, RR, was dragging. All 4 brakes were cleaned, lubed and bled. Raised the rear 10mm as the front was a little higher so this should even it out some more. Raised the exhaust while I was under there as a temp fix as i plan to clock the tips correctly once I finally put the short jzx bumper on the rear. I removed the power steering cooler to see if the system would bleed, sure enough, it did. i had it going from the reservoir to cooler to pump and i think the vane pump sucks and it was causing constant air to be generated. It should work on the low pressure side as its on the push side but thats for another day. Bled the clutch while i was on the bottom and the fork fell out...so i lubed that all up, ordered some cover plates for the r box, and then put the fork back in and continued to bleed the clutch. feels a lot better to shift now oddly lol. still some more things i want to sort out but theyre small and the car functions currently. Need to put miles on it cause it just sits there. sadly its nuclear summer now and it generates a lot of heat 😕 but it stays cool so thats what matters. civic shifter had been feeling poor for a little while now so when i had it in the air last time i took a look. one nut was missing, and the other looked like it was ready to break. i popped it out. took the remaining nut off, welded the top so the captive stud was actually captive. put a new bolt in and lined it up, welded and ground that down, shot it with black, got new crush washers and nuts, cleaned the shifter itself, lubed that all up and popped that back in with the oem shift knob to change it up a bit. while i had the paint out, i splashed some black on the wiper arms as they were nature polished crv has been a non stop fun machine with random failures. the latest has been the fan sensor, it gave up the ghost after 425k kms and has overheated the motor for the tenth time now. already got a new one and looped the fan for the time being so it wouldnt leave my wife and baby stranded in this heat. its not a huge deal as the oem rad and system works so well the fan rarely comes on, but when it needs to be on, i really need it. we went camping in it a few months back. going to get the ac checked out and refill it so might have a few days of ac whats been taking most of my time has been the LS400. i started parting it out and then took the motor out. its heart breaking but the parts have gone on to help save and make a few LS400s a little better with her parts. little over doubled my money and got a free motor out of it so thats a win. covers the loss of the tents at least....ahh yes, the feeling of going back to zero. just started tear down on the 1uz to clean it up and get some paint on the valve covers so it may look fun while it sits there forever. looking forward to this going away. Id get another LS400 for keeps some day. They are a very well built car and appreciated how nice they were to work on and take apart through all of this.
Chitown WaGN....project from hell
Turbocharged400sbc replied to Turbocharged400sbc's topic in Build Threads
poodle skirts EVERYWHERE- 142 replies
- 3800jz buick 3800 turbo
- waGN
(and 1 more)
Tagged with:
¯\_(ツ)_/¯ I'd guess the plastic leg broke. because 30yr old plastics Also Brian is still the man.
I hate bingo 😒 Any good looking gradmas there?
- 142 replies
- waGN
(and 1 more)
Tagged with:
Holly fuck, didn't know that Allis Chalmers upper arms fit a Toyota... But being tractor parts, I doubt you will ever bend them. Nice seat! Where is the other one?
I guess it’s about time I give an update…..the resurrection continues…. Oval tips go WOOWOOOOO…. Next on the list is turbo, injectors, new exhaust manifold and another set of rear wheels. Plan is to get it on the road by spring 2023. The saga continues…
I went to the Buick Club of America meet in Lisle Illinois and boy Gordo you're missing your calling with Grumpy Old Men. I will admit all of them had their wives trained well to answer questions. So many old farts taking a 1908 Buick twin-cylinder out for Joyrides. I swear to God I was expecting a bingo game to break out somewhere.- 142 replies
- waGN
(and 1 more)
Tagged with:
I remember when I was like 8 years old, going to the state fair, and there being a large lines at the freak shows. Just human nature...
- 142 replies
- waGN
(and 1 more)
Tagged with:
LoL, Wut ? Did the scotch tape fail ?
I'll check if my spare is a left or right tomorrow. Can't remember.
Jason started following WTB MX83 Corner Lights
Left mx83 corner light flew off on the highway today. Does anyone have a single or matched pair for sale?
Actually it's been getting a hell of a lot of attention I tried to upload a picture from when it first showed up and it's always had a crowd around it almost all day. Non-stop questions I kind of wish I knew more about the mx62 chassis aside from front brakes smaller than the 2-door Coupe and the rear axle that might as well have toothpicks in the axle tubes- 142 replies
- waGN
(and 1 more)
Tagged with:
So, are you being shunned at the Puick get together? You know, I and everyone else would give you more respect if you had put that engine in a '66 Buick Special wagon, or put a hyper 4AG into the X7. But we all make poor choices in life. I once asked a girl to marry me...
- 142 replies
- waGN
(and 1 more)
Tagged with:
25lb dry chem extinguisher is riding bitch. But didn't need it. Thanks for the towing offer lol- 142 replies
- waGN
(and 1 more)
Tagged with:
Oh, and if you need a tow, I'm only 23 hours away... I charge by the mile,
- 142 replies
- waGN
(and 1 more)
Tagged with:
Hopefully, it won't go up in flames before you get there, so it can take other Puick V6s with it. Honestly, I wish you thee best of luck. You should live stream, just in case.
- 142 replies
- waGN
(and 1 more)
Tagged with:
Well this turd made it into Michigan let's see if it makes it to Ann Arbor and after that up to Flint.- 142 replies
- waGN
(and 1 more)
Tagged with:
