How do you guys feel about RCAs
  • This topic is locked This topic is locked
37 replies to this topic
#21 Kyle
  • 3,823 posts
Posted 21 March 2012 - 11:22 AM
Support the guys that support us, call xm
#22 Guest_DuaxMachine_*
Guest_DuaxMachine_*
Posted 21 March 2012 - 11:28 AM
I don't care if they support us or not, XM's are just shit loads better then titt's3..........
#23 WhoreMouth_Jr
WhoreMouth_Jr
    I !♥ StockTwins
  • 1,496 posts
  • Interests:Dudes, Dicks, Derivatives
Posted 21 March 2012 - 12:02 PM
Iifc for those who care about length
shortest to tallest I think is
Xm<t3<s9
32-33-40
I thinkkkkk
#24 Stephen
Stephen
    GOT MILF?
  • 1,137 posts
  • Interests:Tire Smoke and Boobs
Posted 21 March 2012 - 12:34 PM
^correct.
#25 ChriSOL
  • 3,948 posts
Posted 21 March 2012 - 01:15 PM
nobody else made em when i got mine, including s9 at that point. lol.
#26 Guest_Piner_*
Guest_Piner_*
Posted 22 March 2012 - 07:10 AM
One of the other things they do is correct your camber curve. Struts have a problem of having little to no camber gain under compression (Why Strut suspensions work best with lots of static negative). When the FLCA goes over-under then they actually gain positive camber undercompression. Obviously that shit sucks. So yeah they are a good idea if you are low.
#27 Mitch
Mitch
  • 991 posts
  • Interests:Money<br />bitches
  • Country:Sweden
Posted 22 March 2012 - 11:07 AM
Other than the 1mm of height difference between T3 and XM RCA's, we use steel locating sleeves in our RCA's. The T3 units have thin aluminium locating sleeves, which have been known to sheer off. It happened to my T3's as well as Aphxero's. Also we nickel plate ours which is a much stronger anti-corrosion coating then anodizing.
hope that helps
oh and thanks Kyle and Gordon.
"Fuck Stingrays" - DM Slider
Xcessive Manufacturing <------ Click it!
#28 ChriSOL
  • 3,948 posts
Posted 22 March 2012 - 11:23 AM
interesting. i'd love to see pics of the t3 carnage and im sure Rue would as well.
#29 JoeTheHook
JoeTheHook
  • 698 posts
Posted 22 March 2012 - 02:14 PM
sheared off? how the fuck does that happen? prob wouldnt have happened if he had oak rcas
#30 WhoreMouth_Jr
WhoreMouth_Jr
    I !♥ StockTwins
  • 1,496 posts
Posted 23 March 2012 - 08:41 PM
Threw the Xm ones I got from bwcress today
The difference was like day and night for me, and my car isnt even on the floor.
Car no longer skips up front while hard cornering, just feels alot more predictable.
Would do, but after my mini run-in with T3 I would stay clear just in case. XM or S9 all the way
gonna align it on tuesday, cant wait to see how much that makes a difference as well
#31 Jason
  • 4,254 posts
Posted 24 March 2012 - 07:12 AM
Hey guys. I just wanted to remind you, RCA effectiveness is about as basic of a question as you can get. There is plenty of info on the web which a simple google search would bring back...let alone searching HERE, or any other forum for that matter. I'm glad you guys like to flex your suspension knowledge, but it's all similar concepts from one car to the next.
Then you have the other dude who asks a w58-digidash compatibility question and you send him away, which may or may not have the answer either. I'm glad you guys like to flex your suspension knowledge, but it's all similar concepts from one car to the next.
Basically, what I'm saying is we ought to be a little more supportive with chassis specific knowledge. Except for idiots who think 7M-BHG is a good idea.
#32 Guest_DuaxMachine_*
Guest_DuaxMachine_*
Posted 24 March 2012 - 09:03 AM
I thought 7MBHG was a good idea.........
That way, the drift course stays slippery, and your cars will slide easier.
I have seen many pictures posted that the cars were sliding sideways on wet surfaces.
They were wet due to 7MBHG, right ?
Don't you put the 7M powered cars out on the track first, just to prep the surface ?
#33 Jason
  • 4,254 posts
Posted 25 March 2012 - 01:03 PM
^^^ kekekekeke!
#34 Guest_Rue_*
Guest_Rue_*
Posted 06 April 2012 - 06:09 PM
Sheared off my ass... not possible unless you cut them off, shear off the bolt as well, or maybe had loose bolts. And if the second is the case then you wrecked your piece of shit and something is going to give. Broken wheel, bent lca, "sheared" ncrca...
I absolutely hate T3 but to say the aluminum alignment dowl sheared off is bullshit
#35 Mitch
Mitch
  • 991 posts
  • Country:Sweden
Posted 09 April 2012 - 08:26 PM
It's not a dowel, it's machined surface on the top of RCA. And yes the little lip for alignment broke off. If Aphexro still has his, he can take a pic. I've since have sold mine, and now run XM RCA's. The thin aluminium ring is not strong enough for repeated removal and installation. It's same reason S9 also uses steel dowels like XM does.
#36 Mo
  • 4,044 posts
Posted 10 April 2012 - 04:12 AM
You cant remove the XM units. The generous amount of zinc coating gave me a maigrane pressing the parts together.
#37 Guest_Rue_*
Guest_Rue_*
Posted 10 April 2012 - 02:13 PM
Mitch... you are splitting hairs. I would be willing to blame installation error.
#38 Mitch
Mitch
  • 991 posts
  • Country:Sweden
Posted 10 April 2012 - 09:25 PM
I'm was just giving my review of a product I've owned and used, that's all.
