If your swapping your 1UZ into a different chassis and want to relocate your oil filter, this plate will eliminate the entire cast factory arm and still give you the 1/8" NPT port for oil pressure senders or turbo feed lines. We've threaded the ports with 1/2" NPT to work with most aftermarket oil relocation hose kits allowing easy sourcing of other components. Made from 1" thick 6061 Aluminum, we've machined it for a factory style o-ring and include the bolting hardware required. Just bolt it on and hook up your oil lines.
Price: $ 79.00 / 1
Product code: T-1UZ-OFRP
LINK -------------------------------------> Oil Plate
As always IN STOCK & READY TO SHIP!
