Nice for looks, but I hope no one thinks that is an actual safety piece........
Joint in the middle, with a go-kart tie rod running virtical ?...
...That bar should be one piece from where it bolts to one B piller, to the other, and at least 2, if not 3 virtical braces...
...It would be safer to run a piece of fucking water pipe from one back door to the other........
...I could sit in the rear seat, and fold that piece of crap by pushing on it with my feet.
A frontal impact at just 60 mph will generate 30Gs, or way more than that erctor set death bar will take.
Wow gordon, just wow.
So I felt Rich needed to make a statement on this subject,
FROM RICH: I always love when someone posts an opinion without having ever seen the parts first hand. If they had, maybe they would realize that it’s actually built quite strong, although I did notice your comment about go karts so maybe your perspective is a bit off. I’m not a go kart guy so I don’t think that way.
The cross bar is made from .120 wall DOM steel tube, that’s thicker than Formula D requires in their cages, it’s actually FIA, NHRA, and XDC spec wall. I can guarentee that NO sanctioning body allows water pipe. The center bolt is 3/4", if anyone wants to run the load calcs on that, feel free to post your findings.
I also included a few pics
. You’ll notice the load cell shows 660 LBS, we stopped there with the pull test, please feel free to post pics of yourself squatting over 660 since apparently you can crush our bar/assembly with your legs. The vertical bar has a 1/2" chrome molly clevis end threaded and holds a tension load, please look up the specs and post your findings on capacity.
I’ve also included a pic comparing the factory Toyota shoulder belt bolts to the bolts we supply. I think you can judge for yourself which bolts are stronger, but then again maybe not, ours are. You should also notice that all the assemblies are double shear, the pictures show this quite well but I’m guessing it eluded you. Since you have absolutely no idea how they are assembled, all tube joints are socket fit and then 360 degree TIG welded, the brackets to the door pillars are formed 1/4" plate with the 1/2" arms welded on two separate planes, no single weld ever takes the power unto itself.
If you truly have no first hand knowledge or FACTS on something, please don’t post such strong OPINIONS on public forums about it. You’re attempts to make us look bad are getting old, and tiresome. I hope the members of this forum see your comments for what they are, negative, non constructive harrasment.
So I looked up your statement about the 60mph crash and it causing 30g's of deceleration. That is true but only when you go from 60mph to a dead stop in less than 4 feet according to NHSTA. Which if your 200lbs that causes 6,000lbs of force on your body. It doesn't matter what seatbelt or harness you have installed, ur fucked.
