Xcessive Manufacturing's MX73 steel motor mount brackets for 1UZFE swaps are designed with the correct angle to match up with the stock MX73 cross member, these mounts also work MA6 series and RA6 series '82-'85 Cellica/Supra. We've made these mount brackets with a slot for the motor mount point that allows movement of the engine forward or backward around an inch making trans cross member alignment easier.
CNC cut from 1/4" steel plate, formed and plated, these engine brackets will handle all the punishment you can throw at them and last a life time doing it. If your doing 1UZFE swap into a Cressida, these brackets are what you need. Sold in pairs with all the bolts and washers for both sides.
Stock rubber motor mounts will require the index pin to be ground off to allow these brackets to properly sit flat due to the application of the slotted mount.
Urethane motor mounts shown but not included
Price: $ 91.50 / 1 Pair
Product code: T-MX73-1UZ-MMB
In Stock & Ready to Ship
Link -----------------------------------------------------> X73 1UZ Brackets
