starter info for the W58 and the A340E
14 replies to this topic
#1 kumasan616
  • 455 posts
Posted 20 March 2006 - 01:18 PM
I was doing some comparisons of part numbers and discovered that the starter for the W58 and the A340E are essentially the same... just thought you would like to know that in case you need a starter like I do wink.gif
c33-- JZX's red-headed evil stepchild
kumasan616@hotmail.com
#2 Peewee
  • New Members
  • 289 posts
Posted 20 March 2006 - 08:25 PM
Starter is always the same.
The only starter that *may* differ is the R154 starter.
I seem to recall people saying the flywheel is larger, but not 100% sure if they just meant the clutch area.
M starters are also the same as JZ starters. (close enough)
UZX73
UZZIO
#3 Bōsōzoku_Bro
  • 63 posts
  • Interests:jzx , r32, guitar, slippin wrenches, beer
Posted 29 April 2010 - 03:44 PM
QUOTE (Peewee @ Mar 21 2006, 04:25 AM) <{POST_SNAPBACK}>
Close enough to use???? My starter took a crap on me, have access to a 1jzgte , r154 starter for cheap. Will this work? Also, being on the subject of transmissions, will the a340 work with a 1jzgte? Or no because of bell housing issues? I will eventually be switching to a r154, but want to use the stock cressida tansmission if i can for now.
#4 Foompla
  • 1,376 posts
Posted 29 April 2010 - 03:46 PM
same shit. been swapped forever and no issues.
"What's that?"
*music*
#5 Bōsōzoku_Bro
  • 63 posts
Posted 29 April 2010 - 03:50 PM
QUOTE (Foompla @ Apr 30 2010, 12:46 AM) <{POST_SNAPBACK}>
S0 r154 starter will work on my stock cressida junk?? Thanks for the fast reply.
#6 Foompla
  • 1,376 posts
Posted 29 April 2010 - 04:05 PM
no, i swapped a w58
"What's that?"
*music*
#7 Piggity
  • 134 posts
  • Interests:4dr drifting, working on cars that aren't rusted to shit, etc....
Posted 29 April 2010 - 05:43 PM
It's all the same. W58, R154, and autokraptastic all use the same starter. Well they might not have the same part number, but they work. I've been running my R154 behind my 7M-BHG for the last 6-8months, with the stock cressida starter. Pretty sure the MKII/MKIII Supra have the same starters too.
90' hoopty
#8 rayray
  • 2,810 posts
Posted 29 April 2010 - 06:38 PM
mine's the original 7M starter off the auto as well. running on a R154 behind a 1J atm
BellHelmets.com
#9 zokustyle
  • 686 posts
Posted 29 April 2010 - 07:14 PM
I used 7M automatic cressida starters on a W58 AND R154.
Only difference is on one you need nuts on long bolts and the other threads right into the bellhousing.
#10 Bōsōzoku_Bro
  • 63 posts
Posted 29 April 2010 - 08:59 PM
Well, if you all insist, Ill use the r154 starter. Now, if i could just get the top starter bolt off without killing everyone in the neighborhood while they sleep, due to frustration from lack of a 10 jointed arm and wrench swinging space.
#11 KeCHENG!
  • 71 posts
Posted 29 April 2010 - 11:11 PM
QUOTE (Bōsōzoku_Bro @ Apr 30 2010, 04:59 AM) <{POST_SNAPBACK}>
use a super long extension or pull the alternator and use an even longer extension that goes all the way out there. works lol did it twice....bitch i know
On the search for another sedan...
MA60 2JZGTE BorgWarner 83-75//serialnine-stance coilovers & 5 lug conversion//work equips 019
#12 Jason
  • 3,722 posts
Posted 30 April 2010 - 12:35 PM
QUOTE (rayray @ Apr 29 2010, 11:38 PM) <{POST_SNAPBACK}>
same: stock 7m-a340 starter. 1jz-R154 now
to use the stock cressida a340 auto trans you need a bell housing from a 2jz auto. is300 gs300 sc300 supra etc etc etc.
#13 Bōsōzoku_Bro
  • 63 posts
Posted 30 April 2010 - 02:44 PM
Wow, thanks bros, this info has been very helpful. I honestly don't think I would have gotten that top starter bolt off unless I did like you said, take off the alternator, and run like 4 extensions with a U-joint adapter along the side of the block under the intake manifold. I guess I could have pulled the engine, but thats not until next month when I up greyed to 1j.
#14 Jason
  • 3,722 posts
Posted 30 April 2010 - 07:06 PM
you better watch out for up grayed. i hear he smacks his girlfriends around if they dont pay up.
#15 Bōsōzoku_Bro
  • 63 posts
Posted 03 May 2010 - 05:32 PM
You know this from experience?
