Taken a look at your rear sway bar end links lately? Chances are they're shot. We've put together this set of nylon lined heim joints to replace those old worn out factory end links. The heims thread together to give an adjustable range from 3.7" to 2.8" long (3.2" without cutting the male heim). The mounting studs fit directly into the stock mounting points and come with all the lock nuts required to keep things from comming apart.
Price: $ 39.00 / 1 Pair
Product code: T-SBEL
LINK ----------------------------------------------------------> End Links
I don't know if you guys hav had the same problem, but on all my cressida's the stupid little allen heads always strip out. With these that will never be a problem, plus they are adjustable to fit the needs of the customer. Whether your running the factory "fuel line" I mean sway bar or opted for a stronger after market one from another chassis, our end links can be adapted with ease. And of course IN STOCK AND READY TO SHIP
