We've designed these front tension rod bushing inserts to dramatically reduce the compliance in the stock front bushings. The stock rubber front bushings have designed in gaps to make for a softer ride. These factory gaps allow the front control arms to flex front to rear until the stock snubber washers compress enough to stop the movement. Our insert bushings eliminate all the factory gaps with a firm 80A hardness urethane. The new urethane inserts are contoured to match the factory bushings to eliminate all the gaps and maximize the contact area. Since they fit in the stock location, they can be used with any front tension rods that fit up to the stock bushing. These are a great upgrade for those who want as much control as possible without the expense of solid pillow balls. The design also helps keep the stock rubber bushing from failing due to the abuse of racing and competition.
Features:
Fits directly into stock front bushings
Works with stock tension rods and after market/custom
Dramatically decreases deflection
Reinforces stock bushing increasing lifespan
Sold in complete sets of driver and passenger pairs.
Price: $ 70.00 / 1 Set
Product code: T-MX83-FTRB
LINK -------------------------------> Tension rod bushings
Yet another simple easy to install mod to the cress suspension, as stated above this will work with Stock, JIC Magic, or XcessiveManufacturing tension rods. Take little to no time to install and changes steering feedback greatly.
And Like everything we make there is a ton IN STOCK READY TO SHIP!
