Trap Star 1JZ-GTE UCF20 build.
255 replies to this topic
#1 Guest_Fidel Cashflo_*
Posted 23 June 2011 - 07:00 AM
I've really liked the idea of drifting a sedan for a while now, after seeing countless videos from japan of people sliding Chaser's and Aristo's, I kinda decided to take the plunge.
The Goal:
3200lbs
500whp
1jz-gte (Big single, stand alone, the usual)
R154
Complete 5 speed swap
Modified steering knuckles for more steering angle
I sold my 1992 240sx drift car, here's a link to build on Slamburglars, car only saw the track a handful of times, I'm a big fan of street drifting.
http://slamburglars.com/forum/index.php?showtopic=1378
I decided I wanted to use an LS400 as the chassis for my drift build. I chose a Lexus LS400 UCF20 because of its double wishbone design and superior brakes. It only weighs 3650 from factory and there is a fair amount of weigh that can be shed. I looked around craigslist, found this 1996 Lexus LS400 for $1700 just a few miles away in St Pete. The car had been in a front end collision, driver side quarter panel has a dent in it, but this is the best kind of car to start with for a drift build, I would hate to F*** up a nice car! I started parting out my S13, selling just about everything leaving me with basically just the metal that's left of it.
I picked up the LS, towed it home, the owner said it sounded like the water pump was on its way out, turned out to just be the fan clutch bracket, the bearing was bad. I did the water pump, timing belt, front main seal, caps/rotors/plugs/plug wires, fan clutch bracket, valve cover gaskets, cleaned up everything. I put my HKS filter on (JDM lol).
I traded the MB Battles that were on my S13 for a set of 19x10.5 +15 all around SSR Type C RS wheels. I got some Stickers from SSR, and some SSR Professor center caps, the wheels are currently sitting at the powdercoater's shop. I just need to get some good fitting tires.
Sold the Bride seat and hub, bought a pair of Sparco Evo2 Plus's! I also picked up an IS300 MOMO hub, I'm probably going to sell it and make a custom extension/hub to sit further back. I installed my Nardi 350mm Leather wheel and Circuit Sports quick release into the car. I also picked up a bunch of Donjer Flocking materials. I'm going to be flocking the front door panels and dash/center console in black suede. I already did the steering column cover, it came out very good! Also picked up a CNC Hydro ebrake used.
I ordered a pair of fenders from Dallas Auto, paid $250 shipped for a pair of pretty good shape black UCF20 fenders. I got a pair of corner lights, clear bumper lights and some 6000k HID's for the car.
I picked up a set of coilovers that a buddy made for his LS (Ranlet). They are some custom Bilstein fronts and Koni rears, with some H & R springs, they ride GREAT and are stiff for sliding. My power steering pump leaks terribly, I need to get that fixed soon. Diff will be welded within a week, I'm going to be doing ABS Delete and hooking up the CNC hydro.
I'll update this with more pics and updates as I get more stuff done.
#2 Guest_Fidel Cashflo_*
Posted 23 June 2011 - 07:01 AM
I'm basically going for the look of this car but in a Lexus Sedan form. I'm doing Nissan OEM paint, Platinum Ice Metallic Clearcoat ( KG1) and Dark Gray Metallic Clearcoat (463). This is the color that came on early single cam S13 coupes!
I'm in the process of trading my SSR's for a 1jz/R154 transmission with the owner of a local shop, but I'm not holding my breath. I have the wheels posted a few forums as well as Ebay, trying to get them sold so I can live the inline 6 life. I got my old MB Battles back from my buddy, they also just got powdercoated the same gloss white. Shit's fresh.
My buddy Ryan and I made a bracket to mount my hydro ebrake to my car.
I made a basic diagram for the abs delete and plumbing for the hydraulic handbrake. 3/16" brake hardline and fittings have already been acquired, relatively cheap too, less than $25 in the lines/fittings required to plumb it all. I can't wait for 60+mph handbrake entries!!!
I got the wheels on, rolled the fenders, car now has a nice stance, and its driveable. I had a fair amount of positive camber in the front and rear, so lowering it helped correct the suspension geometry to an extent. It handle MUCH better, I can take on-ramps at like 70mph with not a screech of tire (Hankook Ventus V12 245/40 all around now).
Disregard the sticker, its a long story. I have removed it since the picture after almost getting jumped at a local gas station haha.
#3 Travis
Travis
  • 187 posts
Posted 23 June 2011 - 07:51 AM
I like where this is going...
- Travis
1987 JZX73 2JZGE/W58
Precision 67mm, FFIM, Meth & MAPECU2
1983 MX63 5MGTE/W58.
1980 MX32 4ME/Auto.
formerly BrownMagic
#4 Guest_Fidel Cashflo_*
Posted 23 June 2011 - 07:55 AM
I've recently gone crazy and started gutting the car.
So far I've removed:
Carpet
A Pillar plastics
Lower pillar plastics
Door Sil plastics
B Pillar plastics
C Pillar plastics
Rear seats
Rear seatbelts
Rear deck
OEM Subwoofer
Rear door panels
Spare Tire
Spare Tire cover
Spare Tire cover cover
Cover for the spare tire cover
All of the trunk garbage
I started removing the sound deadening from the floor only so far. I will be doing the Transmission tunnel and rear seat region. The UCF20 didn't come with any sound deadening in the trunk. The car is actually still pretty quiet inside suprisingly, its not bad at all!
#5 bigtoepfer
bigtoepfer
    I♥Japanese Bitches
  • 1,171 posts
Posted 23 June 2011 - 10:44 AM
i like everything about this.
I'd love my car a shit load more too if it never came with a fucking M series motor. - Trevor
Hopeless Romantics
#6 jackc
jackc
  • 507 posts
Posted 23 June 2011 - 12:03 PM
LOL at the rebar sticker
Looks good so far!
#7 CelicaDRIFTER
  • 2,105 posts
Posted 23 June 2011 - 12:50 PM
ooooo interesting. i was toying with the idea of building an LS400 drift car a looong time ago. cant wait to see how this turns out.
www.myspace.com/rrabespl
#8 bigpanda16
bigpanda16
  • 130 posts
  • Interests:tiresmoke, g's, N.GA mountains
Posted 23 June 2011 - 01:33 PM
Very nice.
<img src="http://photos-f.ak.f..._5749_4056.jpg" border="0" class="linked-sig-image" />
track bruiser > street cruiser
<a href="http://www.teamgingerbeard.com" target="_blank">www.teamgingerbeard.com</a>
#9 white_raven
white_raven
    JZsus
  • 786 posts
  • Interests:Science
Posted 23 June 2011 - 01:36 PM
shits legit! and keep the sticker!
Cars: 85 Cressida (1jzgte), 86 Cressida (2jzgte), 00 4runner (5vfe)
Zip Tie Mafia - The Answer to 1984 is 1776.
WTB: r154 clutch, 550cc injectors, is300 Ignition Setup
#10 Guest_Fidel Cashflo_*
Posted 23 June 2011 - 02:36 PM
Sticker has since been removed, I was almost jumped at a gas station in Clearwater haha. Shit's intense.
#11 Gizmo
Gizmo
  • 599 posts
  • Interests:Money, drugs, and hoes! All a nigga knows!
Posted 23 June 2011 - 02:49 PM
Fuuuuuuck that sticker is awesome!!! I wouldve been shot in my block for that hahaha
#12 Bill
    fuck you cressida
  • 3,996 posts
Posted 24 June 2011 - 07:52 AM
i like the plan too. that should work out nice. and with the newer face/lights. nice.
VVT 1JZ X83 ♠ VVT 3UZ S161
#13 slow_n_low
slow_n_low
  • 45 posts
Posted 24 June 2011 - 10:17 AM
why not keep the 1uz in there and just 5spd that and shave the weight..anyway how are you going about mounting the 1j?
I'd rather rock my car on jackstands than those. See if Ja Rule will trade you a signed album for those. You'd totally come out on top.
#14 Guest_Fidel Cashflo_*
Posted 24 June 2011 - 10:55 AM
1st generation GS300 mounts swapped right to left and left to right... It drops right in. I do not like V8's. I do not like 210hp, and 220ft lbs of torque.
#15 white_raven
white_raven
    JZsus
  • 786 posts
  • Interests:Science
Posted 24 June 2011 - 12:14 PM
1jzgte < 1st gen 1uz haha
btw love the sig! haha
#16 Guest_Fidel Cashflo_*
Posted 24 June 2011 - 12:19 PM
For being JZxproject, you guys hate JZ motors.
#17 white_raven
white_raven
    JZsus
  • 786 posts
  • Interests:Science
Posted 24 June 2011 - 12:40 PM
oops i mean for that to be the other way around 1jz > 1uz.
#18 Guest_Fidel Cashflo_*
Posted 24 June 2011 - 12:42 PM
Haha, makes sense.
#19 slow_n_low
slow_n_low
  • 45 posts
Posted 24 June 2011 - 06:04 PM
true true plus they weigh a ton...how does the transmission fit? does it need a shifter extension?
#20 Guest_Fidel Cashflo_*
Posted 24 June 2011 - 07:35 PM
I have to make a rather long shifter extension. I'm not too worried about it, I have my mig up for sale now, just need to get my funds and man up for a tig.
