quick W58 swap q's for a guy with special needs
26 replies to this topic
#1 kumasan616
  • 455 posts
Posted 10 February 2006 - 09:33 AM
okay, so I am about to go and pick up what I need for my W58 swap, here's the list:
W58
shifter assembly (boot, shifter, etc.)
clutch/brake MA70 pedals
clutch master, slave
clutch/flywheel (prob. a stock one, mated behind the STOCK 7M until it dies)
tranny mount bushings
9 inch pink bubble shift knob for those lonely nights :wink:
...now 2 parts I am not sure about
1. the driveshaft, should I pick up an MA70 front driveshaft, stick withh the MX83, use the MX83 output shaft from the tranny, or what? What did you guys use?
2. crossmember... use the MA70 one or the MX83 one?
...anything else I am missing?
c33-- JZX's red-headed evil stepchild
kumasan616@hotmail.com
#2 Angry Slide
  • 355 posts
  • Interests:drift
Posted 10 February 2006 - 10:21 AM
i used the mx83 crossmember and the ma70 front half of the driveshaft. i just used longer bolts withh spacers to bring the drive shaft down a little bit.
#3 toycoma
    SMOKEY
  • 2,545 posts
Posted 10 February 2006 - 10:23 AM
QUOTE (kumasan616)
W58
you need the front half of the ma70 drive shaft and you use the mx83 crossmember. the ma70 crossmember is totally diffrent. but the tranny mounts are the same.
edit: do you have a diff in the car?? i want to know if you get any noises like i am getting. my diff is welded though.
QUOTE (brian)
#4 kumasan616
  • 455 posts
Posted 10 February 2006 - 10:35 AM
no diff yet, I have an MA70 NA LSD sitting in the garage though, its going in as soon as I get the thing rebuilt and get the spacers for it.
...so the front half of the MA70 driveshaft, get MX83 mounts, and keep the MX83 crossmember?
#5 Angry Slide
  • 355 posts
  • Interests:drift
Posted 10 February 2006 - 10:44 AM
QUOTE (kumasan616)
im pritty sure the mounts are the same. if you need one i think i got a couple laying around. just pay postage...
#6 kumasan616
  • 455 posts
Posted 10 February 2006 - 10:50 AM
okay, I'll email you on that... I am also gonna pick up a fresh set of u joints and some longer hardware (what size/length bolts did you use for the MA70 driveshaft for it to work?)
#7 toycoma
    SMOKEY
  • 2,545 posts
Posted 10 February 2006 - 11:01 AM
the tranny mount from the ma70 will work but yeah, mx83 crossmember is needed. which you should already have because........... your putting the ma70 tranny into an mx83. o and read my shifter thing thread, your going to want to do that if the shifter is sloppy. http://jzxproject.com/bbs/viewtopic.php?t=534
QUOTE (brian)
#8 kumasan616
  • 455 posts
Posted 10 February 2006 - 11:45 AM
one last special ed q... does the shifter line up withh the hole for the auto shifter, or do I need to cut up the hole a bit?
#9 Angry Slide
  • 355 posts
  • Interests:drift
Posted 10 February 2006 - 11:48 AM
a MKIII supra W58 fits perfectly, a Celica Supra W58 is alittle short.
#10 kumasan616
  • 455 posts
Posted 10 February 2006 - 01:16 PM
I thought so, just was not 100% sure... thanks for helping out a special ed guy
here's me trying to put together a scrapbook of my ex girlfriends (I lost an earlobe right after this pic thanks to "safety" scissors:
..and thats why I need your guys help!
#11 RiskE86
  • New Members
  • 149 posts
Posted 10 February 2006 - 02:14 PM
just wondering, the clutch master needed is the a70 clutch master too? or just pedals. I tested out a ae95 corolla master but the wiper motor is right in the way.
#12 Angry Slide
  • 355 posts
  • Interests:drift
Posted 10 February 2006 - 02:40 PM
QUOTE (RiskE86)
i havent seen the ae95 mc but you'd think if you used a MA70 clutch pedal you'd need the MA70 master cylinder too since they bolt together. unless the ae95 master cylinder has the same bolt patern as the ma70...
#13 RiskE86
  • New Members
  • 149 posts
Posted 10 February 2006 - 07:42 PM
the ae95 pedal assembly bolts up right to the holes(minus the top mount hole that holds the pedal up top which can just be welded on) but the resivior on the mc hits the wiper motor so it wont sit flush. i was tryin to verify that the a70 one bolts right up, im going to find out on my own in the junkyard i was just seeing if i could get a for sure on it before i spend my time figuring it out.
#14 Skaterjunky8
  • New Members
  • 640 posts
Posted 10 February 2006 - 07:47 PM
I used both the MA70 Master and pedals.
KULA.
#15 kumasan616
  • 455 posts
Posted 11 February 2006 - 04:04 PM
well I picked up the pedals, the shifter and the clutch hard line from the yard today, along withh some other stuff Gabe wanted for cores... just thought I would throw this in: dont forget to grab the clutch hard line to plumb the clutch master to the slave.
#16 RiskE86
  • New Members
  • 149 posts
Posted 11 February 2006 - 05:15 PM
thanks this thread helped me clear some things up too
#17 Skaterjunky8
  • New Members
  • 640 posts
Posted 11 February 2006 - 07:04 PM
If you have a dremel or even a drill you will be ablt to tackle any fitmet issues withh the MA70 pedal and Master. And a grinder/sawsall if you wanna just cut down your pedal rather then changing to the Ma70 brake pedal too
KULA.
#18 kumasan616
  • 455 posts
Posted 13 February 2006 - 08:45 AM
one thing I am getting for sure is a 90 degree bit attachment for my dremel and another one for my cordless drill, that should take care of the clutch alignment. The clutch pedal has a small crack in the stopper brace so I get to do a little welding practice wink.gif
couple more issues:
1. keep the auto MX83 computer, or pick up a manual supra one?
2. speedo-- get a supra speedo cable, or keep the MX83 one?
What did you guys do?
#19 Skaterjunky8
  • New Members
  • 640 posts
Posted 13 February 2006 - 02:18 PM
I got the stock x83 cable to work on my W58, it took a little creativity but it worked. As for the ECU, it will run fine on the Auto and the only side effect that I am aware of is initial throttle responce when taking off in first, so I have heard, I have never really noticed any difference
KULA.
#20 toycoma
    SMOKEY
  • 2,545 posts
Posted 13 February 2006 - 02:49 PM
QUOTE (Skaterjunky8)
i tink i have the regular ecu that came withh the car and i have no problems withh throttle response. there was a manual 7mge ecu laying in the trunk though. might be in the trash now. how did you hook up your speedo cable???
QUOTE (brian)
