SELLING ALL 7MGTE PARTS. MOTOR LEANED OUT AT 20PSI SO HEADGASKET OR RINGS NEEDED. PLEASE PM ME IF YOU DONT SEE SOMETHING LISTED. IF MY PRICES SEEM OUT OF WACK THEN REASONABLE OFFERS CONSIDERED. IF YOU ARE LOCAL THEN OFFER ME BECAUSE THE PRICES I POSTED ARE FOR ITEMS TO BE SHIPPED. CHEERS
85 oil pan with a 7mgte oil pump welded for the front sump
$140+shipping obo
PRICE:250 shipped inc paypal fees. +$150 for intercooler and brackets
ITEM:intercooler piping for 7mgte mk2 supra.
DESCRIPTION: for use with a intercooler that is 25x12x3. will include all black couplers and ss clamps. purple metallic uppers. unseen piping is not painted. if seriously interested can take more pics of piping. comes with a apexi replica bov. homemade piping i quickly made before i put in the 2jz. but the motor blew before i was going to swap the motor lol
PRICE:Valve Covers 40+Shipping, PS Reservoir+Bracket 30+Shipping, PS Pump 50+shipping, Turbo Oil Lines 20+Shipping, Thermostat housings (Sensors included) 50+shipping, Oil Filter Bracket 35+Shipping, Turbo Exhaust Manifold (with shields) 45+Shipping
PRICE:45 shipped inc paypal fees
ITEM:7mgte Cam Gears
DESCRIPTION:Good Condition, no cracks, no chips of teeth, clearly marked alignment
PRICE: All for 125 shipped inc paypal fees
ITEM:Upper Intake Manifold + Throttle Body + Idle Air Controller
DESCRIPTION:Intake Manifold for car with EGR. Will sell separately Manifold for 40+Shipping TB for 40+Shipping IAC 40+Shipping
PRICE:50 shipped inc paypal fees
ITEM:Lower Intake Manifold
DESCRIPTION:No Cracks no gouges on mating surfaces
PRICE: 130 shipped inc paypal fees
ITEM:7mgte Turbo Camshafts
DESCRIPTION: Clean. used.
PRICE: 80 shipped inc paypal fees
ITEM: COILPACKS
DESCRIPTION: i have 2 sets. working condition. used.
PRICE: 60 shipped inc paypal fees
ITEM: 440s 7MGTE STOCK INJECTORS
DESCRIPTION: no problems. used. from a 1990
PRICE:Fuel Rail 30+Shipping, Fuel Pressure Regulator 15+ Shipping, Pulsation Dampener 15+Shipping, All 3 for 50+Shipping
PRICE: 100 shipped inc paypal fees
ITEM: 7MGTE IGNITOR
DESCRIPTION: USED
PRICE: 80ea shipped inc paypal fees
ITEM: KNOCK SENSORS
DESCRIPTION: i have 2 from a 1990
PRICE: 110 shipped inc paypal fees
ITEM: stock AFM with electronics
DESCRIPTION: from a 1990. used.
PRICE: 45 shipped inc paypal fees
ITEM: CAM GEAR COVER
DESCRIPTION: used. not cracked. light scratches only.
PRICE: 65 shipped inc paypal fees
ITEM: 1990 7MGTE ALTERNATOR
DESCRIPTION: never had a problem with it. used.
PRICE: 40 shipped inc paypal fees
ITEM: INJECTOR RESISTOR
DESCRIPTION: used
PRICE: 90shipped inc paypal fees
ITEM: LEXUS V8 AFM
DESCRIPTION:does not come with electronics. no pics atm.
PRICE: 100shipped inc paypal fees
ITEM: 1990 7MGTE MT ECU
DESCRIPTION: works perfect
PRICE: 330 shipped inc paypal fees
ITEM: 1990 7MGTE MT ENGINE HARNESS converted to MK2
DESCRIPTION: works perfect. one vsv connector wiring broken off. NO AC. can include detailed pics and instruction of where to cut and crimp wiring to make plug and play 7mgte harness. (remove 5mge connectors and replaced with 7mgte ones)
PRICE: 575 shipped inc paypal fees
ITEM: CT26 60-1
DESCRIPTION: used about 1000 km before motor gave up
PRICE: 150 shipped inc paypal fees
ITEM: CAM POSITION SENSOR (CPS) FULLY REBUILT
DESCRIPTION: new cps cover, dust boot, External Housing O-ring, Internal Oil Seal, Internal Bearing, Shaft Pin. 1990 model cps
PRICE: 50 shipped inc paypal fees
ITEM: ACCORDIAN HOSE
DESCRIPTION: very new, very soft ruber still. feels like new.
PRICE: $400shipped inc paypal fees
ITEM: BIC 7MGTE CT26 DDP FOR MA60 MK2 SUPRA ONLY possibly x7 cressida
DESCRIPTION: Custom made.Re-routed.Heatwrapped.Wideband 02 bung. Hand built & perfect fitment
ITEM: BRAND NEW SIEMENS DEKA 550CC INJECTORS LOW IMPEDANCE
DESCRIPTION: comes with wiring required. brand new. never used. motor died before i could get it on.
PRICE: $150shipped inc paypal fees
ITEM: BIC '86-'89 1JZ/2JZ swap motor mount brackets
DESCRIPTION: These custom made engine brackets allow you to drop in a 1JZGTE or 2JZGTE into your 1986-1989 MKIII Supra, without having to swap the front crossmember. The brackets are CNC Laser cut from 3/16 steel plate and double welded, and built to withstand any amount of horsepower you can throw at them. They allow use of your original crossmember and uses the square style motor mounts from your 7m engine. These will not work if your car has the round style 89+ motormounts.
PRICE: $300 shipped inc paypal fees
ITEM: 1jz supra rear sump setup(upper & lower oil pan with baffle)
DESCRIPTION:no pics atm. perfect condition though. no dents on lower pan
PRICE: $55shipped inc paypal fees
ITEM: 1JZ Serpentine Belt Tensioner
DESCRIPTION: good condition. no cracks. see pics below
PRICE: $130shipped inc paypal fees
ITEM: 1JZ/2JZ Coilpacks
DESCRIPTION: all in good condition. no cracks. see pics below
PRICE: $60 shipped inc paypal fees
ITEM: 1jz 370cc injectors
DESCRIPTION: working condition last used. see pics below
PRICE: $50 shipped inc paypal fees
ITEM: 1jz fuel rail with regulator
PRICE: $40 shipped inc paypal fees
ITEM: 1jz cam gears
DESCRIPTION:see pics below
PRICE: $100 shipped inc paypal fees
ITEM: 1jz cams
PICS:
