okay i know someone posted that they did this recently but i cant seem to find the post. i was wondering what i need to convert my rear seat belts to the front to have manual seatbelts instead of automatic. not really what i need but what do i have to do?? does it bolt right in? lmk thanks
rear seatbelts to front mod
Started by RoyRogers, Aug 28 2010 04:09 PM
10 replies to this topic
#2
Posted 28 August 2010 - 04:53 PM
You can go to the junkyard and get seatbelts out of a lot of different cars that would work. Thats what I did and they were $5 a piece and I even retained the stock location and plates for the lap belt module. And I used the pair of holes on the B pillar where the track mounted. Not too hard at all. I did, however, have to cut the openings and make them larger but that took about 5 minutes to do.
Some people like to kiss, some people like to hug, some lesbians like eatin' each others shit out of a cup.
The Buttery Biscuit Blog
#3
Posted 28 August 2010 - 10:27 PM
it was jzxpwns...
i took my b-pillar trim off but didn't see anything threaded other than the two small bolts for the track, so i was a little curious on how folks were mounting these up.
Kyle Phelan, on 01 February 2011 - 04:06 AM, said:
Ps: all that hellaflush/Stanceworks/stancenation scene-ster shit is gay. They say it's a lifestyle, but so is homosexuality.
#8
Posted 23 January 2011 - 10:18 AM
i know its a fairly old thread but.....does anyone know what cars have manual seatbelts that will work w/ the x8. i put the rear belts in the front of my car but they are a pain in the ass cuz the belt locks. apparently if the belt mechanism is not at the exact angle as how is mounted originally then i will not slide out...it will just stay locked.
#9
Posted 23 January 2011 - 11:17 AM
for reference, canadian x8 b-pillars are different and the belts do not bolt on. for a proper setup it will require cutting and welding fabrication of the b-pillar seatbelt mounts, and don't fool with that shit if you don't have to or you're going to get facesmashed to shit.
#10
Posted 23 January 2011 - 02:03 PM
rear belt recievers from ~1984 camry. The cressida's belt blades are strangly wide. Those are the only ones I could find that fit.
