I did a bit of searching both here and on google but didn't come up with anything conclusive. What is the range of the stock 1JZ MAP sensor? 2 bar, 3 bar, eleventeen bar?
1JZ MAP sensor range
Started by JimmyHoffa, Aug 26 2010 09:53 AM
2 replies to this topic
#2
Posted 26 August 2010 - 10:46 AM
Well, they transmit a voltage. So you could go to the setting option on an SAFCII or newer and plot a voltage for a given boost pressure. You will have to determine the sensors maximum voltage signal output and just multiply your voltage by boost. Are these a 0-5 volt?
Should be easy to figure this out, and this way you would have ACTUAL data and not internet intelligence on the matter.
Thank You
Sincerely
-NASA
Thank You
Sincerely
-NASA
