So yeah, vvti 2jzgte's have that drive by wire throttle bodys...
Replacing it with a normal throttle body and running throtle cable should be fine right? as long as its still has a tps to read off of?
In my case, im planning on running a knockoff Greddy intake plenum, a Q45 throttle body, stock ecu w. safc2
also read something where the dbw t/b controls idle instead of using a idle air control valve like the non vvti engine.
hmmm...
getting rid of drive by wire T/B question
Started by CelicaDRIFTER, Jul 12 2010 11:08 PM
9 replies to this topic
#1
Posted 12 July 2010 - 11:08 PM
www.myspace.com/rrabespl
#2
Posted 13 July 2010 - 02:49 AM
from what i could tell on the n/a vvt 2j in my old is300, it looked to me like there was 2 throttles, one was servo operated by ecu and one had the physical connection by throttle cable. the physical one would open with your foot, but the servo one just ahead of it would open when it god damned pleased to make a smooth opening (delayed response). i always thought you could just take off that servo operated butterfly (the plate) and leave the servo in with the shaft still turning but doing nothing to restrict the throttle opening, should work? not sure if the gte vvt is the same setup though. just a brainstorm. never got a chance to screw with it when i had the car.
#4
Posted 13 July 2010 - 09:29 AM
QUOTE (Kyle Phelan @ Jul 13 2010, 12:15 PM) <{POST_SNAPBACK}>
So there's no iacv on there? I was gonna say jzx100 ecu or jzx100 powerFC, and an earlier throttle body.
yeah, theres no IACV
i was gonna try to do jzx100 harness and power fc. but no luck finding a jzx100 harness.
#6
Posted 13 July 2010 - 10:02 AM
Since on the DBW set up the TPS has been moved to the accelerator pedal, I'm sure you can wire up a cable operated throttle body to read the same signal off its TPS. The issue you might run into is when the computer requests action form the throttle body motor and the computer not receiving a signal back from it, the computer might throw a code and put itself into limp home mode and kill power. Thats just my opinion, I could be wrong.
"Torque is what turns tires into white smoke, but 494 bhp at 8250 rpm turns grown men into giggling girls."
#8
Posted 13 July 2010 - 05:31 PM
jzx100 ecu has different ecu plugs and its hard to find a jzx100 engne harness.
or should i just stick with the damn DBW throttle body/ intake?
#10
Posted 13 July 2010 - 06:18 PM
what year camry plugs?
friend of mine has a haltech platinum pnp for a 350z. i messaged haltech's tech support to see if it can be used on my 2j. if im able to use it, i might just get it.
