Lovin the same Cress since '05
42 replies to this topic
#1 MentalStruggle04
  • 71 posts
Posted 03 July 2010 - 06:51 AM
Here are some pics: 2007ish
Well after a few thousand dollars over the last few years I've decided i'm putting money into a dieng 7M. Low compression in Cyl. 4 and 5. Distributor leaking oil, crack coolant tube pipe (not hose) between the engine and firewall, oil in my spark plugs (needs boot seals done), and worst of all.. Automatic...
So its JZ time. More pics on page 2.
Engine
1JZ-GTE + M/T ECU + Complete Wiring Harness + R154 5 Speed Transmission ($2055)
Driftmotion 1JZ AFPR kit with Aeromotive AFPR ($260)
1JZ-GTE Complete Engine Gasket kit [Including: Cam seals, Front/Rear main seal, Valve Guide Seals, Fuel Injector seals, O-Rings, Valve Cover Gasket (grommets included), Intake/Throttle gaskets, Exhaust gaskets, Oil Drain gaskets, Water Pipe gaskets, and Head Gasket.] ($167)
2JZ-GTE Denso Fuel Pump ($149)
1JZ-GTE Intercooler ($145)
1JZ-GTE Intercooler Piping ($145)
MKIII Toyota Supra Solid Engine Mounts ($130)
JZX90 Engine Brackets (121$)
2JZ-GTE Water Pump (119$)
2JZ-GTE Throttle Cable ($68)
1JZ-GTE Fuel Dampener Bypass Hose ($65)
1JZ-MX83 Custom Power Steering Line ($65)
1JZ-GTE New Power steering/Alternator/Fan Pulleys ($58)
1JZ-GTE Serpentine Belt ($56)
1JZ-GTE Intake Kit + Air filter ($55)
1JZ-GTE/2JZ-GTE Timing Belt Tensioner ($52)
NGK Iridium Spark plugs ($43)
LS400 Lexus Fan Clutch ($35)
1JZ-GTE Timing Belt ($25)
1JZ-GTE Thermostat ($17)
FIPG Black ($12.50)
Power Steering Reservoir modded to fit (7MGE, free)
Radiator (7MGE, free)
Radiator Hoses (7MGE, free)
Starter (7MGE, free)
Radiator Fan (7MGE, free)
A/C Lines (7MGE, free)
Drivetrain
R154 5 Speed Transmission (Included with engine)
Beech Performance Short throw shifter ($260)
R154 Clutch Kit ($235)
MKIII Toyota Supra Clutch and Brake pedal assemblies modded to fit MX83 with clutch master cylinder ($100)
MKIII Toyota Supra Front Driveshaft ($54)
Full Length Clutch Line (Freebie, $35 value)
1JZ-GTE ARP Flywheel bolts ($30)
R154 Clutch release hub kit w/o hub, just washers and clips ($25)
R154 Marlin Crawler Polyurethane Socket ($8)
Clutch Master Cylinder (Included with clutch pedal, free)
Clutch Slave Cylinder (Using old one, free)
Flywheel (Resurfacing)
Speedo line (MX83, free)
Rear driveshaft (MX83, free)
Auto Tranny Mount (MX83, free)
R154-1JZ Bellhousing (included with engine, free)
Electronics
1JZ-GTE M/T ECU (Included with engine)
1JZ-GTE complete harness (Included with engine)
7M-MX83 complete harness ($55)
Power Sexy Inc. Conversion Harness (Thanks Guy!)
Igniter (Included with engine)
Boost/Vac Gauge ($30)
Custom Boost/Vac Gauge Mount ($46)
#2 Guy Smiley
  • 480 posts
Posted 03 July 2010 - 07:02 AM
That is a beautifully kept car! Seems like you are on the right path. Great intro thread too.
Welcome
#3 MentalStruggle04
  • 71 posts
Posted 03 July 2010 - 07:48 AM
Thank you. And actually, through browsing these forums, I came across a post saying you could do 1jz+mx83 wiring? Is this true?
QUOTE (Guy Smiley @ Jul 3 2010, 11:02 AM) <{POST_SNAPBACK}>
Welcome
#4 redbullx83
  • 615 posts
  • Interests:beer and pizza.
Posted 03 July 2010 - 08:35 AM
Very nice welcome.
#5 Mo
    I♥UZ
  • 2,873 posts
Posted 03 July 2010 - 12:01 PM
Holy crap, what motor is that?
#6 Hen(Tai)
  • 172 posts
  • Country:Nepal
Posted 03 July 2010 - 02:01 PM
Did your grandparents shave off the Toyota logo?
Welcome.
4 Doors, 6 Cylinders and 3400lbs of GO FUCK YOURSELF
#7 CelicaDRIFTER
  • 1,864 posts
Posted 03 July 2010 - 02:43 PM
wow. super clean!
www.myspace.com/rrabespl
#8 rayray
  • 2,813 posts
Posted 03 July 2010 - 07:26 PM
probably repainted. emblem looks to be slightly off of its original location. but then again i haven't looked at the ass of my cressida in the past 6 months
BellHelmets.com
#9 MentalStruggle04
  • 71 posts
Posted 03 July 2010 - 08:27 PM
Nah those emblems dont need to be shaved they aren't permanent. I just removed the emblem as a whole and left the cressida logo. Don't want people thinking its an old Corolla or somethin. It's a cressida! It's a 7M-GE just well taken care of for a 20 year old engine. Either way it's not as mint condition anymore which is why a 1JZ sits in my garage being restored.
#10 mcfizzle
    I♥1U
  • 968 posts
Posted 03 July 2010 - 09:13 PM
FINALLY a decent intro.
More awesome than a robot caveman punching God in the dick.
#11 Jason
  • 3,723 posts
Posted 04 July 2010 - 05:08 PM
7M-GE! No shit?!!?
#12 iw86
  • 40 posts
Posted 05 July 2010 - 01:59 PM
Welcome. Clean looking car bro, wish mine was that clean with gray trim and interior.. Also looks like you have been doing your homework. Congrats lol cya around.
#13 spooklover69
  • 152 posts
  • Interests:cars &amp; girls
Posted 06 July 2010 - 10:21 AM
this thing is FUCKIN FRESH ........ do you have any plans for rims or suspension????? post some pics of the build lookin good!
#14 MentalStruggle04
  • 71 posts
Posted 06 July 2010 - 10:36 AM
I dont have any pics of the build yet. I'm doin this by myself and my only camera is my phone. I don't want to get oil and crap all over my iphone! I'll take pictures before I start workin on it tomorrow. I'll probably be going with S9 coilovers and 17" idkwhats with +idkwhatoffset. I'll figure that out after I get this JZ alive. For now I'm trying to figure out what to do about the harness. I can't seem to get in contact with Guy Smiley or Aphxero (Mark, right?). I'll keep everyone posted
#15 ChriSOL
  • 2,117 posts
Posted 06 July 2010 - 11:23 AM
QUOTE (MentalStruggle04 @ Jul 6 2010, 06:36 PM) <{POST_SNAPBACK}>
Pussy. It wipes right off mine.
#16 JDM CRESS
  • 741 posts
Posted 06 July 2010 - 11:54 AM
thats forkin clean!
#17 TougeCrameryRollinNice
  • 681 posts
  • Country:Nigeria
Posted 06 July 2010 - 01:05 PM
put some jz & S9 in your minty cress and you'll get doubled rainbowed ALL DAY!!
totally freshida.
JDM VIPness
#18 CRES
  • 182 posts
  • Country:Philippines
Posted 06 July 2010 - 08:10 PM
Welcome!
#19 MentalStruggle04
  • 71 posts
Posted 07 July 2010 - 02:26 PM
So I got a nice little check and I bought the rest of what I need except a 91 7MGE Cressida Harness. My cress is my daily so I don't want to pull the harness if I don't have to. As soon as I can get another 7M harness in my hands I'll be sending it out with the JZ harness to be converted. Either way with the parts bought and a few more tools purchased I was able to make some more progress.
Goodbye old 1JZ Hydraulic pump
Hello 2JZ shiny pump!
Well with that done next is front seal, then cam seals, then timing belt. I need to go to the store to buy star shaped bolts, an air compressor, air impact gun, air die grinder, cut off wheels, hose, etc. Then ill be able to mount my clutch pedal, mod the bumper for the FMIC, take off my flywheel to have resurfaced, and change my rear main seal. I have oil buildup all over the Power Steering and A/C housings as well. Anyone know of a common culprit?
#20 GRAFH
  • 136 posts
  • Interests:J-TIN
Posted 07 July 2010 - 07:23 PM
looks clean.
