1j speed sensor
4 replies to this topic
#1 toyotatodd
  • 109 posts
Posted 19 June 2010 - 03:23 PM
ok so my tranny doesnt have a speed sensor on it. only wires it has are for the reverse lights. its an r154 and it was bolted to the engine when i got i. my question is what is going to happen if i dont have a speed sensor i have been searching and cant find the answer anywhere. is there a way to bypass this and make the car run fine? will it just spit a code for the speed sensor and run fine? just curious because my trans didnt have one on it when it arrived it has a piece of a speedo cable where they cut it off. thanks for the help in advance
89 X8 1JZ 5 SPEED
#2 aphxero
  • 3,247 posts
Posted 19 June 2010 - 03:51 PM
it will throw a code. and you can go over 115mph.
#3 toyotatodd
  • 109 posts
Posted 19 June 2010 - 09:47 PM
so in order to get the CEL to go off a speed sensor would have to be installed? i guess if it will run fine without it then its not gonna get one.lol
89 X8 1JZ 5 SPEED
#4 mranlet
    Bigger Body
  • 799 posts
  • Country:Russian Federation
Posted 20 June 2010 - 06:24 PM
You pull the bulb and since your car is pre-OBDII nobody is the wiser at emissions testing.
#5 toyotatodd
  • 109 posts
Posted 20 June 2010 - 10:10 PM
yeah thats what im gonna wind up doing. and we dont have emissions here so im good to go with that
89 X8 1JZ 5 SPEED
