1989 cressida with a jzx90 harness and 1j will not start need help
33 replies to this topic
#1 vert88
  • 35 posts
Posted 19 June 2010 - 11:36 AM
So I wired the car exactly like the drunken wiring and the thing will not start I swapped parts with my supra and my supra starts but not the cressida I checked for continuity on the crank censors and everything has power that's suppose to have power and the car still will not start so I am stumpt. I have been going over diagrams and everything on the forum and checked and double checked my wiring and it still will not start. I am going to run the car with an auto so if anyone has any advice or picture of the bare minimum wires I would really appreciate that if not I will have to take my car to 935 so that rob can look at it
#2 Guy Smiley
  • 480 posts
Posted 19 June 2010 - 01:05 PM
Sounds like a problem with your Main Relay circuit (MRel). Double check the IGSW 7.5amp fuse under the dash and make sure you have power to the injectors/coils.
#3 aphxero
  • 3,247 posts
Posted 19 June 2010 - 01:34 PM
QUOTE (Guy Smiley @ Jun 19 2010, 10:05 PM) <{POST_SNAPBACK}>
^this
And sometimes shitty x90 ecu wont trigger mrel even with igsw input. In that case just do key on like the older cars. Just cut the mrel wire by the ecu and tie it into the igsw wire.
#4 vert88
  • 35 posts
Posted 19 June 2010 - 04:32 PM
I have 12 volts to the injectors and the coils and 11.5 to mrel and I checked it when it was cranking and it only dropped to 10 volts. I have a chaser harness that I am about to extend but I have no ecu. You guys have any other ideas that I could try out
#5 iheartMX83
  • 940 posts
Posted 19 June 2010 - 09:54 PM
i drilled hole. and ran my x90 harness through the foot vent and sat the ecu under carpet. you wire up the fuel pump ? just saying
#6 vert88
  • 35 posts
Posted 20 June 2010 - 11:13 AM
The fuel pump comes on with ignition I am just stumpt I am like all out of ideas here guy I really need some help
#7 vert88
  • 35 posts
Posted 20 June 2010 - 12:08 PM
Do I have to run all my speed sencors if I am running an auto in my car and also te1 comming from the ecu has 12 volts commimg out of the ecu so where should that go. Throw me some help here guys
#8 MX83MISSILE
  • 210 posts
  • Interests:turbo cressida
Posted 21 June 2010 - 05:11 PM
Check out your crank angle sensor and cam angle sensors make sure they are plugged in and check the shielding for these three sensors for ground .
Good luck
mx83 cressida 1jz-gt vvt-i 5spd
fx16 20v 5spd
Pete, MX83MISSILE
#9 Guy Smiley
  • 480 posts
Posted 22 June 2010 - 11:40 AM
Plug in your Water temp sensor.
#10 vert88
  • 35 posts
Posted 23 June 2010 - 05:04 AM
I checked all these sencors and they are all good I don't know what I am doing wrong. Coils and injectors get their power from that plug next to the fuse box by the battery I jump the fuel pump from the ignition source in the engine bay all my connectors are on. I know the ignitor and the ecu work cause I checked them on my supra whick had a 1j I just don't know what is wrong with the car, it has power to everthing and still no start, I have to be missing something like a neutral safety wire or something. I will keep plugging at it.
#11 Guy Smiley
  • 480 posts
Posted 23 June 2010 - 11:43 AM
Have you tried starting it with starting fluid? Go simple on your approach and you will find a simple answer.
#12 vert88
  • 35 posts
Posted 27 June 2010 - 11:38 AM
So I still could not get the car started but I am not giving up yet I am going to install a 2jzgte wiring harness and computer and see if its the harness that is bad cause everything else works on the car and that seems to be the only conclusion.
I figure since the 1j and the 2j share the same censors the harness should be easy to install
#13 aphxero
  • 3,247 posts
Posted 27 June 2010 - 02:54 PM
let us know what you come up with.,
#14 vert88
  • 35 posts
Posted 07 July 2010 - 08:28 PM
So i replace the jzx90 harness with a harness out of a chaser and the same thing happened so tomarrow i am going to go thru the motor to see if i did something wrong. I have 12 volts to the coils and the injectors but i dont know if the injectors or the coiled are getting a pulse so i am going to find a diode light to see if there are any type of pulse from the injectors or the coils.
#15 Kyle
    The Phelan
  • 2,170 posts
Posted 08 July 2010 - 05:12 AM
What ecu are you running and are you sure it's good? Also, are you sure the harness is pinned for the e u you're using? Because if it's not, you'll have power, just no signal.
#16 vert88
  • 35 posts
Posted 08 July 2010 - 05:48 AM
Well i think i will have to repin the plugs going into the ecu cause i am using a jza70 ecu with the extra pigtail on a chaser harness cause i was told it should just be a plug and play but i am going to check out the schematics when i get off work. I know the ecu is good, I rode in the supra that it came out of.
#17 Kyle
    The Phelan
  • 2,170 posts
Posted 08 July 2010 - 09:04 AM
Time to find some pinouts, but if it was me I'd start pretty much from scratch. Cut every thing open, trace, label, so on... Good luck
#18 vert88
  • 35 posts
Posted 12 July 2010 - 05:40 AM
Still no change i checked all my wires and the are all going to where they need to be, i am just stumpt about the wiring of this car, i was also wondering if the auto tranny computer sends a signal to the ecu to tell it to send a pulse to the injectors and the coils cause i checked for voltage and everything and there is just power going in but no pulse from the ecu but i know the ecu works because it came out of my friends car when he swapped from a 1 to a 2j there is got to be something that i am not hookinh up because i have followed the wiring to a T and still nothing and i am even using a harness that the only mod on it is the extention. If you guys have any input or went thru this dilema please write me your inputs thanx
#19 MX83MISSILE
  • 210 posts
Posted 12 July 2010 - 03:41 PM
fuel pump resistor - 12v mod ?
fx16 20v 5spd
Pete, MX83MISSILE
#20 vert88
  • 35 posts
Posted 13 July 2010 - 08:52 AM
fuel pump gets power to it 12 volts
