so i went on the hunt last night since phonix tuning keeps blowing my off about sending an invoice for the body side ecu plugs needed for my swap and found the perfect car for plugs. If you need coil pack plugs-alternator plug-ecu plugs or any other plug every plug you need will come from a 94 camry 3.0 v6. the avalons use the same coil pack plugs but only have three of them. i was in the jusk yard for 3 hours searching cars and this is the car that has it all. i got 15 coil plugs and the ecu plugs for 15 bucks which is a shit load cheaper than paying for brand new ones. just thought i would share the info since i couldn't find a straight forward answer for where to get the plugs
1jz chaser harness plugs-1jz connectors
Started by toyotatodd, Jun 17 2010 11:26 AM
10 replies to this topic
#6
Posted 17 June 2010 - 02:59 PM
yeah just keep goin douch. i fuckin searched my ass off why dont you give it a try and see what you come up with. the coil plugs looked the same i was not aware they were different. i have also been searching for knck sensor plugs i havent found a match for that one yet though. if you figure it out please let me know as i also need one
89 X8 1JZ 5 SPEED
#7
Posted 17 June 2010 - 03:06 PM
searched for one second out of curiousity.
bam
http://jzxproject.com/bbs/index.php?showto...COIL+PACK+PLUGS
easy peazy.
no need to get worked up. it happens. but at least you found a solution instead of cluttering the forum up like most noobs.
bam
easy peazy.
BellHelmets.com
#8
Posted 17 June 2010 - 03:13 PM
i am curious as to why the coil plugs from a 94 wont work they look the same and plug into the 1jz coil packs i havnt actually ran the car with them on the harness yet but they seem to be exactly the same. the coil packs on the 94 look exactly the same also. i was just wondering what the difference is between 1j plugs and the ones i have. im not trying to act a fool sry bout the shit talking.
89 X8 1JZ 5 SPEED
