OK, there has been a lot of discussion concerning these mounts lately, so I wanted to let everyone know what the scoop is. These mounts are made out of 1/4" thick bent steel. A lot of people have been concerned about the mounts bending, which is a valid concern if you are not familiar with things of this nature. There is nothing you could throw at these that would cause them to bend. It takes over 7 tons to form them....... thats 14,000 lbs. If you are putting a 20 cylinder locomotive Diesel engine in your car, then maybe you have a problem, but no JZ or even V8 equivalent would cause these mounts to fail or bend.
These are available off of
http://www.xcessivemanufacturing.com/merch...=211&step=4 for $89.50 a set.
As you can see, they are plated and come with the hardware needed. These mounts are for Kouki crossmember ONLY! We just took the needed measurements last night for Zenki corssmember and should have them in about 2 weeks. I will keep this updated so you will know right when they are ready.
Please ask any questions you may have. I will be monitoring this thread several times a day...... so just ask.
Thanks for looking
