1jz part out
34 replies to this topic
#1 CelicaDRIFTER
  • 1,864 posts
Posted 16 June 2010 - 11:52 PM
copied my thread from supramania.
So, i had no luck selling as a whole so this is the next best thing. Tryin to get my 2jzgte vvti goin already.
its a JZX90 1jzgte.
prices dont include shipping
located in Downey
celicadrifter@sbcglobal.net
JZ oil level sensor - $100
(2) cam position sensors - $30 ea. SOLD
stock water cooled oil cooler - SOLD
cam gear back plate - $10
coil packs, brackets painted hot pink, missing one boot - 3 of them SOLD, got 3 left. $75 for the 3
timing sprocket - $40
1jz head(no valve covers and cam sensors)w. cams/cam gears - $200
1jz bottom end with new front/ rear seals minus pan/ sump - $300
aristo motor mounts with good rubbers - $100
1jz harness, a/t wires and some other bs removed but not depinned from ecu plug - $300
sidefeed fuel rail for 1j - SOLD
used oem 2jzgte water pump itself, no housing - SOLD
used timing belt idler pulley - $40
used timing belt tensioner - SOLD
stock VVTI 1jz topfeed rail - $40
vvti 2jzgte harness and ecu - $800
vvti 2jzgte upper intake and drive by wire t/b(needs tps) - DBW tb SOLD make an offer on the upper intake manifold
www.myspace.com/rrabespl
#2 turbowhooo
  • 2 posts
Posted 17 June 2010 - 03:33 AM
what were you asking for the whole shebang?
#3 CelicaDRIFTER
  • 1,864 posts
Posted 17 June 2010 - 04:11 AM
was asking $1300
http://jzxproject.com/bbs/index.php?showtopic=4381
#4 trinicressida
  • 17 posts
  • Country:Trinidad and Tobago
Posted 17 June 2010 - 01:55 PM
what is required to use th evvti top mount rail ? is there any brackets needed to bolt securely to the twin turbo 1jz?
#5 CelicaDRIFTER
  • 1,864 posts
Posted 17 June 2010 - 01:57 PM
QUOTE (trinicressida @ Jun 17 2010, 09:55 PM) <{POST_SNAPBACK}>
from what i was told you'd have to use the lower intake off the vvti 1jz to run it.
#6 redbullx83
  • 616 posts
  • Interests:beer and pizza.
Posted 17 June 2010 - 02:23 PM
Do u have the power steering pump?
#7 Foompla
  • 1,379 posts
Posted 17 June 2010 - 02:39 PM
1j = 2j alt right?
I was thinking about going to adams kart track tonight. are you around there?
"What's that?"
*music*
#8 CelicaDRIFTER
  • 1,864 posts
Posted 17 June 2010 - 02:43 PM
QUOTE (Foompla @ Jun 17 2010, 11:39 PM) <{POST_SNAPBACK}>
1j = 2j alt right?
sorry, no p/s pump.
i think theyre the same. Adams is about an hour away from me.
#9 Foompla
  • 1,379 posts
Posted 17 June 2010 - 06:15 PM
meh. didnt feel like sittign in 3 hours of traffic. ill be in touche
"What's that?"
*music*
#10 ChriSOL
  • 2,118 posts
Posted 18 June 2010 - 05:32 AM
send pics of the manifold to me?
its t3 divided, started out as an ebay manifold? WG pipe inside or outside runners? thanks.
#11 CelicaDRIFTER
  • 1,864 posts
Posted 18 June 2010 - 10:08 AM
QUOTE (ChriSOL @ Jun 18 2010, 02:32 PM) <{POST_SNAPBACK}>
#12 Mitch
  • 888 posts
  • Interests:Money<br />bitches
  • Country:Sweden
Posted 21 June 2010 - 04:04 PM
do you have the stupid little plate the igniter bolts to?
"Fuck Stingrays" - DM Slider
Xcessive Manufacturing <------ Click it!
#13 CelicaDRIFTER
  • 1,864 posts
Posted 21 June 2010 - 07:01 PM
yeah, the ignitor has the bracket.
#14 xtriumphx818
  • 2 posts
  • Interests:cars...<br />shows...<br />gurlllsssss!
Posted 24 June 2010 - 10:32 PM
interested in igniter..
cash in hand..
hitt me up asap
(818)422-8821
$$cashh in handd!!$$
#15 CelicaDRIFTER
  • 1,864 posts
Posted 24 June 2010 - 10:53 PM
QUOTE (xtriumphx818 @ Jun 25 2010, 07:32 AM) <{POST_SNAPBACK}>
cash in hand..
hitt me up asap
(818)422-8821
still got it.
hit me up.
(562)233-8467
#16 Gibbs
  • 1,205 posts
Posted 25 June 2010 - 06:31 AM
Map sensor you still got this?
Alexi From Nori Yaro
#17 Tatmatt
  • 10 posts
  • Interests:really...fucking knitting
Posted 25 June 2010 - 08:20 AM
Got the box of goodies, Man packing was top notch. I want the throttle bracket got the funds. I was wondering do you have the oil level sensor from the pan and if so how much for that as well?
#18 CelicaDRIFTER
  • 1,864 posts
Posted 25 June 2010 - 09:10 AM
still got the map sensor, the other stuff i'll check on tonight after i get home from work.
#19 Gibbs
  • 1,205 posts
Posted 25 June 2010 - 09:25 AM
Anyway you can let it slide for $50 I'm in a crunch and need it bad?
#20 CelicaDRIFTER
  • 1,864 posts
Posted 26 June 2010 - 10:29 PM
dont have the oil pan sensor. theres a block off plate where it would be at.
