Diff
24 replies to this topic
#1 Demesio
  • 428 posts
Posted 12 June 2010 - 08:12 PM
Alright i got me a 87 supra LSD from the junker the other day (half off) for 20 bucks.. broke it apart and seems flawless, i'll be putting it in tomorrow, any advice on how?
im considering just swapping internals.. i'll post up pics as i do it smile.gif
#2 aphxero
  • 3,247 posts
Posted 12 June 2010 - 08:20 PM
Reuse cressida shims and just check backlash. Anything from about .004-.008 is usually okay
#3 CelicaDRIFTER
  • 1,864 posts
Posted 12 June 2010 - 08:22 PM
Swapping internals is one way to do it. are you keeping the cressida gearing? That diff off an NA or turbo supra? Turbo has 3.73 or 3.9 gears and NA has 4.3.
On mine im using the whole pumpkin, just swapped the rear mount/cover. I also made spacers for the front.
www.myspace.com/rrabespl
#4 Demesio
  • 428 posts
Posted 12 June 2010 - 08:28 PM
^it was off the na smile.gif... i was thinking of doin the same, but i wanst sure of how to do the front mount
#5 aphxero
  • 3,247 posts
Posted 12 June 2010 - 08:37 PM
Oh yeah I forgot switch the ring gear over haha.
#6 Demesio
  • 428 posts
Posted 12 June 2010 - 08:41 PM
Sweet smile.gif.. thanks
#7 Skin
  • 241 posts
Posted 12 June 2010 - 11:17 PM
any one have a list of diff ratios on what can be swapped into x8?
Difference between models etc like 81 83
#8 Kyle
    The Phelan
  • 2,174 posts
Posted 13 June 2010 - 06:14 AM
yeah, supramania has it listed like a gazillion times 'cause dumbshits don't understand you can look for the shit before asking
#9 Demesio
  • 428 posts
Posted 13 June 2010 - 02:12 PM
whats the difference with the ring gear?
#10 CelicaDRIFTER
  • 1,864 posts
Posted 13 June 2010 - 03:45 PM
i decided to be nice and look this up.
info tag on your firewall or supra firewall or wutever has the code that will say what size diff/ gear ratio it has.
http://www.supramania.com/forums/showthrea...g+pinion+ratios
Axle Codes:
First Digit = Ring Gear Diameter
A=138mm
B=145mm
C=6.25"
D=6.62"
E=7.1"
F=7.5" ('82-'86 A6 chassis)
G=8" ('86.5-'92 A7 chassis)
H=9"
J=9.25"
K=9.5"
L=10.5"
M=12.5"
N=13.5"
P=14"
R=162mm
S=6.38"
T=6.7"
U=6"
V=10.6"
W=15.5"
X=142mm
Y=158mm
Second and third digits = Gear Ratio
01=3.30
02=3.36
03=3.545
04=3.556
05=3.70
06=3.889
07=3.90
08=4.111
09=4.222
10=4.375
11=4.444
12=4.625
13=4.79
14=4.875
15=5.125
16=5.286
17=5.60
18=5.714
19=5.833
20=6.167
21=6.667
22=6.78
23=6.833
24=7.64
25=4.556
26=5.571
27=3.364
28=4.300 (MA70 NA)
29=4.100 (JZA70)
30=3.727 (Late '89+ MA70 Turbo)
31=3.909 ('87-'89 MA70 Turbo)
32=6.591 OR 5.583
33=7.503 OR 5.583
34=6.781 OR 4.786
35=7.636 OR 5.600
36=4.778
37=3.583
38=3.417
Fourth Digit (number of pinion gears / LSD or Open)
2=2 Pinions Open
3=2 Pinions LSD
4=4 Pinions Open
5=4 Pinions LSD
#11 Demesio
  • 428 posts
Posted 13 June 2010 - 03:49 PM
haha almost done... another thing to add on...
if you're swapping internals... gotta swap the supra axle shafts and diff carriers as well happy.gif
#12 Mo
    I♥UZ
  • 2,873 posts
Posted 13 June 2010 - 04:25 PM
Did you figure out what ratio you have?
#13 Demesio
  • 428 posts
Posted 13 June 2010 - 04:31 PM
its the 4.3
#14 Mo
    I♥UZ
  • 2,873 posts
Posted 13 June 2010 - 04:33 PM
Thats cool. Then you'll be able to start off in 4th gear and plow fields with it and shit.
#15 Demesio
  • 428 posts
Posted 13 June 2010 - 05:08 PM
#16 Mo
    I♥UZ
  • 2,873 posts
Posted 13 June 2010 - 05:11 PM
Dude, W58s don't fit on Cressida's. I got a mint Auto, we'll just do a trade and you can give me 20 bucks.
#17 Demesio
  • 428 posts
Posted 13 June 2010 - 06:59 PM
haha my auto hasn't seen 1st gear in months sad.gif.. or second for that matter... my city mpg sucks balls
so here's my car smile.gif... let all the diff fluid out
had to take the muffler off
the two diffs.. mine's on the left
took me a while to get it out but there's the lsd and taking the off the ring gear
when it was time to put it back together.. the axle shafts werent going all the way in... i noticed that the x8 ones are barely bigger so i put the supras' in instead and the diff carrier was different as well, again the x8 were bigger
here's where i stopped for the day.. kinda... i left the diff under the car sittin on the floor...
my dumbass dropped it on my finger and well FML
#18 Mo
    I♥UZ
  • 2,873 posts
Posted 13 June 2010 - 07:32 PM
how's your diff bushings?
#19 Demesio
  • 428 posts
Posted 13 June 2010 - 07:40 PM
#20 rayray
  • 2,813 posts
Posted 14 June 2010 - 01:14 PM
what supra did you pull that diff from? all i did was swap the ring gear and reused all cressida bearings and was good to go.
BellHelmets.com
