clutch discs...
9 replies to this topic
#1 CelicaDRIFTER
  • 1,864 posts
Posted 30 May 2010 - 12:07 PM
clutch discs arent supposed to have play in the center splined section... right?
this clutch disc i have has a bit of up/down and side to side play.
www.myspace.com/rrabespl
#2 mranlet
    Bigger Body
  • 799 posts
  • Country:Russian Federation
Posted 30 May 2010 - 12:23 PM
It's sprung hub. That's fine. The splines sleve rides in a plate that is held in place by the springs. If it was a solid hub you'd need a new disc.
#3 CelicaDRIFTER
  • 1,864 posts
Posted 01 June 2010 - 01:00 PM
took it to a clutch shop, it was a bad thing. getting it fixed for $20
#4 Foompla
  • 1,378 posts
Posted 01 June 2010 - 03:00 PM
just jam a paper towel in it.
"What's that?"
*music*
#5 mranlet
    Bigger Body
  • 799 posts
Posted 02 June 2010 - 10:55 PM
What sort of "bad thing" are we talking about? Worn out captive hub or something?
#6 CelicaDRIFTER
  • 1,864 posts
Posted 02 June 2010 - 11:27 PM
the amount of play the hub had on the clutch disc.
#7 Mo
    I♥UZ
  • 2,873 posts
Posted 03 June 2010 - 02:12 AM
Your not supposed to have play. The springs absorb the shock from the clutch disc when it comes in contact with the nflywheel so it takes some of the slack to minimize wear and tear in the whole driveline.
#8 mranlet
    Bigger Body
  • 799 posts
Posted 03 June 2010 - 02:21 PM
Well duh it's the play of the clutch hub. LOL. My question is what caused it?
#9 Mo
    I♥UZ
  • 2,873 posts
Posted 03 June 2010 - 10:33 PM
^poor craftsmanship..
#10 CelicaDRIFTER
  • 1,864 posts
Posted 04 June 2010 - 08:58 AM
wutever was holding the plate that has that splined sleeve in place was worn somehow.
