Wiring gremlins: opinions welcome...
3 replies to this topic
#1 Rob.K
  • 8 posts
Posted 28 May 2010 - 04:05 PM
I'm thinking that there is a possible wiring problem/short in the harness or elsewhere. The new front clip put on this jzx has gone through 3 ecu's now, and apart from the shitty nature of the jza70 ecu there must be something going on here. In addition to this problem, the fuse for the gauges keeps blowing out. Not sure if the two are related but I thought I'd mention it.
I'm going to be pulling the dash this weekend and pulling off the harness to double check things. Anyone have any suggestions on what this could be or where to look? this car was also an auto and changed to manual, so there's a bunch of open clips too.
ps.already fixed some poor grounds around the car and checked injectors and all is good.
Thanks in Advance.
#2 Guy Smiley
  • 480 posts
Posted 29 May 2010 - 09:42 AM
Is it the IGSW fuse that is blowing? I know that fuse controls the gauge cluster on my car. If that is the case there may be a problem in your Main Relay (MRel) circuit.
#3 Rob.K
  • 8 posts
Posted 29 May 2010 - 01:24 PM
QUOTE (Guy Smiley @ May 29 2010, 06:42 PM) <{POST_SNAPBACK}>
It's a 7.5A gauge fuse in the kickpanel... so ya I believe so. That's a good suggestion, I will check it for sure.
#4 mranlet
    Bigger Body
  • 799 posts
  • Country:Russian Federation
Posted 29 May 2010 - 02:12 PM
Sand down your body grounds. 9 times out of 10 "wiring gremlins" turn out to be poor or missing grounds.
