So car is running! Woot!... Couldn't figure out why the starter wasn't engaging so I took a wire and attached it directly to the solenoid and then to a switch with 12v... started up first try
Drove it around a bit, wasn't running too strong but wanted to make it to the closest station to put some new gas in her. Tranny is shifting hard, thought the dipstick read that there was enough fluid. Back it up, its still running, put it in drive and were off. Car doesnt want to accelerate much but its slowly getting up there... get to the station and she starts billowing smoke from underneith... check it out and the cat is smoking like crazy, think nothing of it and throw some gas in it so it can start running a bit better... start driving around again and its slowly getting faster and faster, not smoking or making any funny noises.. but handles like a boat... head back to shop and its still running smooth... speedo stopped working halfway through the drive.. have to re hook that up later.. pull it in, park and turn it off... all seems good till i decide to look under the car...
Underneith is a pool (and growing) of atf that I just put in about 15 minutes before... rear main seal is blown and is leaking everything onto the ground...
So now i guess ill just drive it around till the tranny goes.. maybe the 1J will have to happen a couple weeks early!
Lowering coming tomorrow...
