I have looked around and can't find it does anyone's
have the diagram on hot wire them. Headlights.
how to wire mark 2 lights?
Started by redbullx83, May 09 2010 03:40 PM
11 replies to this topic
#2
Posted 09 May 2010 - 05:05 PM
black to black....red to red....white to white....green to green....
J/K, but what are we doing here. Mark 2 lights to what? It shouldn't be that hard, just swap yours out an literally you should only have a few wires per light. try it one way, if it doesn't work try another way. worst case you blow a bulb or a fuse. either way its not expensive.
sorry im no help
sorry im no help
#4
Posted 09 May 2010 - 06:35 PM
wuts the difference?
different headlight bulb plug?
wiring fog lights?
or tail lights?
wiring fog lights?
or tail lights?
www.myspace.com/rrabespl
#6
Posted 10 May 2010 - 05:16 AM
I'm same boat here. Aaron says it will be really easy to do John, I'm pretty sure if your headlights are like mine you got the connector on them plus about 6" of wires. Mine are all red with black stripes. There are 3 for the main bulb and another 3 for the fog lights.
Doing the marker lights is easy, you just have to figure our which ones they are and what they do. For bulbs that flash with signals, tap the signal wires. For bulbs that light with parking lights, you can use the wiring for the MX83 sidemarker/position lights.
#7
Posted 10 May 2010 - 09:09 AM
for headlights, replace 9004 plug with that h3 plug. thought mark II was h4. well, just try to figure out what wires what.
#8
Posted 10 May 2010 - 09:14 AM
it is. the H3 is for fogs. i ran a relay and separate power and switch for the fogs. switched plugs to run H4 from 9004 (HB1). easy peazy. i'm no electrician and i can still do this in 30 min
BellHelmets.com
#10
Posted 30 October 2010 - 04:54 PM
i'll be in the garage later today, i'll just snap some pics, easier to explain
BellHelmets.com
#12
Posted 30 October 2010 - 06:39 PM
i explained what i did here http://jzxproject.co...?showtopic=2843 previously
i'll throw some pics up in there later
BellHelmets.com
