the plan was to make just a fun weekend track/dd car, reliable and street-able, around 300whp would be prefect i think...
this car was has been through the s13 community and came out worse then the whores in downtown portland...
bent subframe, crack RLCA, shit had positive offset in the rear and it sat higher then most stock x8, rear wheels had the mounting faces had been ground down for higher offsets? idk... car was fucked. picked it up though cuz it was running and had 5sp swap. I work a fucking lot, so its going slower then I'd like but you know, you either have lots of time and no money or lots of money but no time... i'm kind of some where in between with no time and only some money to work with.
so first thing i did was cut the springs, i dont really care what anyone says, riding high is worse the cut springs IMO... then replaced subframe and RLCA's
then found a guy selling 2jzge (na-t) out of his MKIV supra with trans and everything.
new clutch: spec 6puck
new rear main while I had access...
then while I was still driving the 7m around, it exploded on me...
it might be a little hard to see but thats the rod sticking out of the hole there in the block...
