brass freeze plugs vs steel?
7 replies to this topic
#1 heyitsmarksupG
  • New Members
  • 16 posts
Posted 02 May 2010 - 11:59 AM
Which freeze plugs are better on the 5m 7m 1j and 2j? Steel or Brass? OEM or not?
I've got a pin-hole cracked in one of my freezeplugs. whats the easiest way to remove this plug? i've heard about drilling a hole in it and yanking it out. I've tried JB Welding it, (sadly).
this is gonna be a DIY and i dont know how much shops will do this so i'd liike to try it out
#2 Rag
  • 106 posts
Posted 02 May 2010 - 01:01 PM
Punch/drill hole into the center, i like using my tiny 2lb slide hammer with an L bracket and tapping it out (this works most of the time for me), i have also used screw drivers to mangle the plug enough so i can get some visegrips or a clean strike with a punch. Once out make sure the block surface is clean. I bought an installed tool ages ago and the little drivers work... but a properly sized socket and a small hammer works just fine too. Top off coolant, remove airpocketss and double check for leaks.
I have no preference brass vs steel as i get whatever is avaliable, i do not like the expanding rubber plugs used in long term applications.
#3 heyitsmarksupG
  • New Members
  • 16 posts
Posted 02 May 2010 - 08:58 PM
yeah...I think i'll try your way. Easier said than done though.. did you remove your powersteering?
#4 super-hachi
  • 20 posts
Posted 03 May 2010 - 04:15 PM
use steel plugs.. there like that facory for a reason. brass and cast iron expand at different rates. brass works in aluminum cause they both expand fast.
#5 DirtyMonkey
  • 544 posts
Posted 03 May 2010 - 05:12 PM
If you lack Driving skills, Add more Horsepower.
#6 heyitsmarksupG
  • New Members
  • 16 posts
Posted 07 May 2010 - 06:28 AM
awesome. thanks everyone with your input. wish me luck. Toyota Fest this saturday, hopefully i have my cress finished by then. if not, for sure JCCS
#7 Jason
  • 3,723 posts
Posted 12 May 2010 - 07:55 PM
wtf really?
freeze plug threads?
whats next?
"what kind of air should i put in my tires?"
>>from a compressor.
>>>what kind of compressor should i use? hand pump, foot pump, bicycle pump? how long will it take with the bicycle pump? cause i need to spend as much time as possible posting shit threads on JZXP and cant dilly dally with this bicycle pump business.
>>>>i heard nitrogen is good to use in your tires...which kind of pump will pump nitrogen the best?
#8 heyitsmarksupG
  • New Members
  • 16 posts
Posted 15 May 2010 - 12:24 AM
fuhh-getta bout it...I just JB welded that ish. Imma just run this cress till it cant take it. Ugh. Someone spare me a JZ. just send it to my house its XXX Blah Ave.
