MX73 and 83 radiators
7 replies to this topic
#1 David McNamara
  • 52 posts
Posted 27 April 2010 - 09:20 PM
Well i searched and didnt find anything, but I was wondering if a 83 radiator is the same as the 73?
I have seen a few of both, but I have never really looked at them. The only reason I am asking is because on the trip back from Cali with my car I screwed the radiator up pretty bad with debris, and a few other things and there is a 83 at the junk yard with a good radiator....
well to make a long story short, it runs around 200 degrees now when it was running closer to 170 before when on the same road, and running near the same speed. I have tried to use an old radiator fin straighter tool that my dad had but its just too bad, i think the tire that hit the front of the car really did the most damage to it.
Anyways, let me know, I just dont want to take it off and then need to start to piece things together to make it work
THANKS
#2 Gibbs
  • 1,205 posts
Posted 28 April 2010 - 12:49 PM
73 is single core the 83 is dual core
Alexi From Nori Yaro
#3 brian
    I♥1J VVT-i
  • Root Admin
  • 3,572 posts
Posted 28 April 2010 - 01:05 PM
yeah basically toyota added a core to get it BHG-Ready™
#4 David McNamara
  • 52 posts
Posted 28 April 2010 - 07:27 PM
will it physically fit int he same spot? of will I need to fab up a few things? i am fine getting and hacking a different radiator hose up, but I just didnt want to have to make brackets to hold the thing in place and cups for it to sit in if I didnt have to.
THANKS
#5 Gibbs
  • 1,205 posts
Posted 29 April 2010 - 03:33 PM
Should fit I don't see why not
#6 Mo
    I♥UZ
  • 2,863 posts
Posted 10 May 2010 - 07:40 PM
Your going to have to modify the X73 Fan Shroud if you plan on keeping that thing.
#7 David McNamara
  • 52 posts
Posted 12 May 2010 - 08:19 AM
QUOTE (CACressida @ May 10 2010, 11:40 PM) <{POST_SNAPBACK}>
eahh thats something minor. As long as it will mount up im good. Honestly, worst case I will just use a set of aftermarket fans that I have sitting around from my old S2000.
#8 Mo
    I♥UZ
  • 2,863 posts
Posted 13 May 2010 - 10:58 AM
E-fan FTW
