Trying to set up my sards on the PFC and I need to know the latency on the oem 1jz 370cc injectors.
I assume since it's a denso, that it could be the same as a sr20/rb20 at 0.58ms
oem 370cc injector latency
Started by Ninjabread, Apr 26 2010 02:29 PM
5 replies to this topic
#4
Posted 28 April 2010 - 02:05 AM
Just realized, I'm using 800cc low impedance, which are 0.75ms.
Mark, what injectors were you basing your correction off of?
I'm assuming if the oem's are 0.528ms, that would mean a correction of +0.22ms
QUOTE
Hey I love the taste of the wheel rim to the deep personal! I would certainly feel the wheel of the sports, the man ultimately decides the wheel rim deep balls!
#5
Posted 28 April 2010 - 07:13 AM
Matt you should check for 2jz 440 and not 1j as its a 2j PFc.
#6
Posted 28 April 2010 - 01:06 PM
Doh!!
thats true.
*edit: just found it, its actually 0.9 for the 440's which explains why my car was running poopy. Should be running -0.15 correction instead.
thats true.
QUOTE
