Posted 18 May 2010 - 04:29 PM
Yea, you cut the black/oranges and hook them up to the 6 black wires on the resistor box, then take the 6 black/orange leads coming from the ECU and hook them all up into the red wire.
This works for me since I'm using a 2jz power FC, which means my injectors all figure individually, as opposed to batched like a stock 1jz (2 are on the same pin). If thats the case, you do the same thing, but you only have to worry about 3 wires since they aren't split.
And no, its not the grounds. You are actually interupting the 12v source. The ECU grounds out the injectors to fire them.
QUOTE
Hey I love the taste of the wheel rim to the deep personal! I would certainly feel the wheel of the sports, the man ultimately decides the wheel rim deep balls!
