X83 digi dash wont light
24 replies to this topic
#1 ChriSOL
  • 2,117 posts
Posted 16 April 2010 - 04:46 AM
Awesome super mega thanks to feisar who supplied me with a cluster, harness and now a dimmer.
Everything in the cluster not digital lights up. Dimmer makes the odometer backlight brighter and dimmer and I get warning lights in the bottom. Pushed all the buttons and turned all the knobs: nothing from the gauges themselves.
I have checked all fuses unless the digi dash requires extras that aren't on the usdm fuse panel cover diagram. The dimmer, mirror, upper radio controls, black boxes and cluster are plugged in. Fuel level sender was replaced with brand new digital unit. We are sure the wiring is correct.
Any help appreciated, new Canada guy w/ 1j and digi cluster or feisar smile.gif
#2 ChriSOL
  • 2,117 posts
Posted 16 April 2010 - 08:50 AM
im trying to eliminate simple things first. is there anything that NEEDS to be plugged in and functioning for the digi portion of the cluster to light up?
i.e. switches, boxes, connectors to ECU?
#3 ChriSOL
  • 2,117 posts
Posted 16 April 2010 - 11:30 AM
pps, working to get the car started and driving tomorrow afternoon so gauges would be a plus smile.gif
#4 Bill
    keep it stupid simple
  • 3,142 posts
Posted 16 April 2010 - 12:52 PM
hmm. check that the power related wires have power in them? maybe a change at a harness plug might not be connected?
i know the dash worked when I pulled it from the car.
if i think of anything i'll post it.
#5 brian
    I♥1J VVT-i
  • Root Admin
  • 3,573 posts
Posted 16 April 2010 - 01:17 PM
you got all the diagrams i assume?
#6 ChriSOL
  • 2,117 posts
Posted 17 April 2010 - 06:10 AM
we used the usdm diagram, discovered that most of the wires in the opposite side of the connectors on each harness serve the same function and are even hte same color.
wouldnt hurt to have the canadian one too but i havent seen it online... aphxero said he had one but then he sold his car and forgot about posting it.
#7 cianide
  • 162 posts
Posted 17 April 2010 - 06:43 AM
If anybody has them, I can host them if they aren't already up. Interested in doing this swap as well.
I tune cars for a living. I am addicted to late 80's and early 90's cars. I need help.
1989 Baby Blue Cress
2005 Envoy
http://agendachaos.com
#8 ChriSOL
  • 2,117 posts
Posted 18 April 2010 - 02:50 PM
If anyone else is interested I will confirm what is needed when I figure it out.
#9 ChriSOL
  • 2,117 posts
Posted 19 April 2010 - 12:27 PM
bump. holding me up big time, i'd rather find out from someone with knowledge if i left something out than tear the whole thing apart or start buying replacement parts.
i believe feisar when he said that the cluster lit when he pulled it so that leaves something not being plugged in right for it to work or maybe wiring.
#10 super-hachi
  • 20 posts
Posted 20 April 2010 - 03:10 PM
hey man just got your pm sorry.
all the lights on the cluster that arent the digi stuff should power themselves. the digi portion needs an ignition source. im guessing your tach, speedo, temp and fuel dont light up but what about the PRND2L? i dont thin it should unless the rest of it worked .
if you check the diagram for the car the digi cluster came out of. note the pin position of the ign source as it should have to be moved or possibly added into your factory conector
and if you want you trip meter to work make sure a B+ wire goes to that or it resets everytime the car is shut off
hope this helps. ill try to find my wiring stuff and remember what i did exactly. and if you got the msd tach adapter dont hardwire it just yet... mine took some finess to make it work.. the instructions have 4 or 5 ways of putting it in and the one that seems most likely was wrong haha. (2jz)
#11 ChriSOL
  • 2,117 posts
Posted 20 April 2010 - 04:05 PM
Hey thanks for looking. Yeah I get nothing from the digi portion. But I'll reheck the harness this weekend. Haven't started the tach adaptor yet, thanks for catching me on that.
#12 1bad89
  • 117 posts
Posted 22 April 2010 - 09:35 AM
what does this cluster look like? where can i get one?!
#13 ChriSOL
  • 2,117 posts
Posted 22 April 2010 - 11:41 AM
it looks like hammered shit you dont want one trust me. only fags get them for their cars and im a fag.
#14 rayray
  • 2,813 posts
Posted 22 April 2010 - 01:29 PM
QUOTE (1bad89 @ Apr 22 2010, 10:35 AM) <{POST_SNAPBACK}>
easy, go pull one from a junkyard in canada
BellHelmets.com
#15 Bill
  • 3,142 posts
Posted 22 April 2010 - 02:22 PM
#16 mervins
  • 905 posts
  • Interests:Toyota's, big booty bitches, kush and,beer.
Posted 22 April 2010 - 04:51 PM
You kidding me is that the famous digi dash off a canadian cress? If so that shit is tight , looks like a f1 fighter panel.
I bet that circular gauge on the right is for homing in on enemies. lol.
Chrisol sell me one!
THE DUDE ABIDES!
#17 rayray
  • 2,813 posts
Posted 22 April 2010 - 08:06 PM
factory 6 spd too... so i heard.
BellHelmets.com
#18 ChriSOL
  • 2,117 posts
Posted 23 April 2010 - 05:11 AM
plibt
#19 1bad89
  • 117 posts
Posted 23 April 2010 - 07:53 PM
QUOTE (ChriSOL @ Apr 22 2010, 07:41 PM) <{POST_SNAPBACK}>
thats cool. i do better with pics. hammered shit or not i want to see it, and i dont really care to know your sexual orientation.
#20 rayray
  • 2,813 posts
Posted 23 April 2010 - 08:52 PM
i think bill had the pics of his, it had a bhg icon too if i remember. toyota really thought it through on this one
BellHelmets.com
