ABS Delete
36 replies to this topic
#1 Piggity
  • 134 posts
  • Interests:4dr drifting, working on cars that aren't rusted to shit, etc....
Posted 27 March 2010 - 10:42 PM
How do you get rid of it? I want to run 18x9.5 +35 with a 225/40R18. I read G's post about angle and how you'll hit the unit if you have to big of wheels/tires.
Also, my steering rack is leaking out of the tie rod ends a lot. I don't want to drive the car right now because of it. Has anyone ever rebuilt their rack and how hard is it to do? Do you need specific tools to do this? Are kouki racks the same as zenki? I have another parts/shitty car that's a 91', but the car I'm driving right now is a 90' MX83.
90' hoopty
#2 oreofreak
  • 199 posts
  • Interests:Drifting
Posted 28 March 2010 - 06:12 AM
I am having the same problem with my new jzx81. I am going to replace all the brake lines with brand new non abs lines. I have already priced them from toyota. It wont cost no more than $80 here in japan. Then i am going to pull all the crap out.
All I really wanted was the back visor
92 JZX90 Creasta
92 GX81 MarK II sedan
#3 lucas
  • 1,286 posts
  • Interests:$$$
Posted 28 March 2010 - 12:43 PM
QUOTE (Piggity @ Mar 27 2010, 11:42 PM) <{POST_SNAPBACK}>
For the ABS search the forum. There is a lot of info on it.
I cant help you with the rack...
Xcessive Manufacturing
#4 rayray
  • 2,813 posts
Posted 29 March 2010 - 04:22 PM
we have awesome rebuilders here in cali for shit like ps pump, steering rack, etc. you guys don't have nothing like that up there?
BellHelmets.com
#5 lonelywanderer
  • 373 posts
  • Country:United States Minor Outlying Islands
Posted 29 March 2010 - 05:02 PM
find a non abs car in the junk yard and take the harware out. if i remember right their are some specialty tools for rebuilding the rack
#6 Piggity
  • 134 posts
Posted 29 March 2010 - 05:33 PM
Thanks guys.
Every single x83 in the junkyards I find are ABS equipped. I think all the cressida's in Canada came like that. I have searched and I couldn't find shit all. Maybe I didn't search with the right words. EDIT.....FOUND IT.
Is the kouki rack the same as the zenki rack on these cars?
90' hoopty
#7 mr2thomas
  • 218 posts
Posted 29 March 2010 - 07:51 PM
whatd you search to find it?
im having a hard time finding it. abs is too short. and when i accompany it with anything else it comes up with nothing of help
WWW.BITCHESLOVEMY4DOOR.COM
#8 Rag
  • 106 posts
Posted 30 March 2010 - 02:20 AM
search for abs*
But i too found nothing useful in a search
#9 miles
  • 515 posts
  • Interests:drift
Posted 31 March 2010 - 07:52 AM
its really not hard, i think you need to get a non ABS master cylinder and basically just make new lines from that to your front brakes and the rear brake distributor thats bolted to the strut tower on the driver side. the rear lines shouldnt matter, just got back there and take off the ABS things attached to the hub.
or just go to the junk yard and get non ABS lines for the front, not a big deal.
but i do think you need a NON-ABS master iirc. which you can get from a local parts place.
QUOTE (brian @ Dec 3 2008, 03:05 AM) <{POST_SNAPBACK}>
....rare as sober chick in vegas.
hahahaha
"Yes, it really got suspended for 12 years."
- Me
#10 Rag
  • 106 posts
Posted 31 March 2010 - 04:43 PM
I plan to tackle my ABS delete alongside the jz swap, finishing s9 coils and fitment work. I'll see if i can price and check availability on oem prebent lines when i go into work...
#11 Bill
    keep it stupid simple
  • 3,144 posts
Posted 01 April 2010 - 04:01 PM
easy if your engine is out, just remove all the hardlines, get a flaring tool and proper ends, some brake line, some t-fittings where needed, and an aftermarket proportion valve if you wanna get fancy. you can just redo all the lines, it's not as hard as you might think.
as for racks, i'm considering switching to an s13 rack since i have a spare even with a column if needed. but not everyone is so handy.
#12 Rag
  • 106 posts
Posted 01 April 2010 - 05:13 PM
1990 TOYOTA CRESSIDA LUXURY 3.0L 2954cc L6 MFI (M) [7MGE] DOHC : Steering : Rack and Pinion Complete Unit
A-1 CARDONE Part # 261675
ACDELCO Part # 3612126
1991 TOYOTA CRESSIDA LUXURY 3.0L 2954cc L6 MFI (M) [7MGE] DOHC : Steering : Rack and Pinion Complete Unit
Swap the racks. A reman rack runs 220usd before shipping and after a 90usd core, locally it was about 340usd after core.
#13 Skin
  • 241 posts
Posted 02 April 2010 - 06:15 AM
i removed mine in the 81, just unbolted all including master cly, make sure u get the proportioning valve aswell, then just bolt in all non abs lines and master
#14 brian
    I♥1J VVT-i
  • Root Admin
  • 3,573 posts
Posted 02 April 2010 - 08:06 AM
you can keep the abs master, you just need the lines and prop valves. i'll be doing this swap shortly.
#15 Mo
    I♥UZ
  • 2,873 posts
Posted 02 April 2010 - 10:31 PM
What do you mean by hitting the ABS master? Your talking about the ABS pump?
#16 Hater
  • 369 posts
  • Interests:Levitating.
Posted 03 April 2010 - 10:08 AM
I took a saw to the box and cut out the right corner, then grinded the shit out of it. No more rub and I can finally go full lock!
I'll snag you some pics. It was really easy to do provided you have the right tools thup.gif
#17 Hater
  • 369 posts
Posted 03 April 2010 - 10:49 AM
Janky mo fucka
#18 mranlet
    Bigger Body
  • 799 posts
  • Country:Russian Federation
Posted 04 April 2010 - 09:15 AM
Problem spotted
Action taken
Problem solved
ABS modules have proportioning in them, so if you just get rid of them your bias will be all goofy.
For steering rack, let someone else rebuild it and just buy one of these:
http://www.steeringrack.com/
#19 Skin
  • 241 posts
Posted 05 April 2010 - 12:13 AM
QUOTE (brian @ Apr 2 2010, 04:06 PM) <{POST_SNAPBACK}>
ive no idea how you can keep the abs master its totally different.
I know i couldnt
Also to post above ^ just get the prop valve aswell then your bias will be fine
#20 exciting sedan
  • 118 posts
Posted 05 April 2010 - 02:27 AM
QUOTE (brian @ Apr 2 2010, 09:06 AM) <{POST_SNAPBACK}>
that'll be cool if you can do like a write up or show pics when you do yours, since pretty much everyone with ABS wanna get rid of it including myself.
- Jason I.
89 Cressida ... in the works
my blog
