Mk2 Supra Clutch pedal in a MX83 Unveiled!!
18 replies to this topic
#1 Mo
    I♥UZ
  • 2,873 posts
Posted 02 February 2010 - 12:04 AM
I asked Push if the MK2 Clutch pedal would work in a Cressida and he said that Kamasama..or watever his screen name is said that it wont work. I say nay nay! Ditch the MK3 piece of shit pedal, the MK2 is a better flush fit and its perfectly straight. Also, it has the bonus brackets which you have to drill into the firewall below the windshield if you remove that plastic grill under the wiper to access it. I'll post pix of my 5spd swap much later on, but this was just rigged up in my Cressida that I'm scrapping.
#2 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 02 February 2010 - 12:19 AM
Uhhhh ya.. i've been telling ppl this for years. . You only need a diff master and rod (depending on your setup. .) but at least the pedal itself BOLTS RIGHT IN. .
G.
G.
#3 Mo
    I♥UZ
  • 2,873 posts
Posted 02 February 2010 - 12:44 AM
QUOTE (Gseventythree @ Feb 2 2010, 12:19 AM) <{POST_SNAPBACK}>
G.
Where ya been all my life?!
btw, what clutch master you use?
#4 bradlee
  • 383 posts
Posted 02 February 2010 - 07:04 AM
Yep, just mounted one up in my car. The only thing that concerns me is if I'm getting the full travel I need. The face of the pedal itself sits nearly half an inch closer to the firewall than the hacked auto brake pedal beside it. I'm using a Mk2 clutch master too, since that's what lines up. The reservoir interferes with the wiper motor, so I've removed it for now. Eventually I'll just create a remote reservoir (like G has mentioned before).
View PostKyle Phelan, on 01 February 2011 - 04:06 AM, said:
Ps: all that hellaflush/Stanceworks/stancenation scene-ster shit is gay. They say it's a lifestyle, but so is homosexuality.
#5 Mo
    I♥UZ
  • 2,873 posts
Posted 02 February 2010 - 10:12 PM
Stock MK3 Supra clutch masters have a forward tilted reservoir which worked great on my gold car.
#6 timtiminy
  • 9 posts
  • Interests:Outdoors, fitness, health. Bicycles, running, rock climbing.
Posted 24 August 2010 - 10:35 AM
okay so mkII clutch pedal and clutch master cylinder with mkIII clutch master reservoir?
#7 redbullx83
  • 615 posts
  • Interests:beer and pizza.
Posted 24 August 2010 - 11:31 AM
U can use a master from a celica 93ish it clears the wiper motor.
#8 timtiminy
  • 9 posts
Posted 25 August 2010 - 07:21 AM
alright so the 90-93 celica clutch master cylinder is drop in no mods needed? bolt holes line up and all the linkage line up and everything with enough travel to fully actuate the clutch?
#9 CelicaDRIFTER
  • 1,864 posts
Posted 25 August 2010 - 10:06 AM
http://jzxproject.com/bbs/index.php?showtopic=4529
www.myspace.com/rrabespl
#10 JoooeOne
  • 88 posts
Posted 19 December 2011 - 03:24 PM
what about the brake pedal do you modified it? cuz my clutch pedal it like really near to the brake pedal
#11 DuaxMachine
    tenacious 7M owner
  • 1,418 posts
  • Interests:Keeping a 7M running when so many others can't.
Posted 19 December 2011 - 04:25 PM
First, did you leave the fucking full size auto brake pedal in the car ?
Take that bitch out, and trim it down.
You can cut it all the way doen to fit the stock manual pedal rubber cover,
or, since you continue to polute the forum with that ae86 avatar,
you can fit what ever neon lighted pedal cover you can buy off eBay.
"TRY TO FATHOM THE HYPOCRISY OF A GOVERNMENT THAT REQUIRES
EVERY CITIZEN TO PROVE THEY ARE INSURED...
BUT NOT PROVE THEY ARE A CITIZEN."
One of my X8s:
http://rides.sportcompactcarweb.com/ride/1...sida/index.html
My eBay items:
http://my.ebay.com/ws/eBayISAPI.dll?MyeBay...me=STRK:ME:LNLK
#12 Mo
    I♥UZ
  • 2,873 posts
Posted 19 December 2011 - 08:34 PM
Change your avatar before we change it for you and make it a permanent pink penis.
Correct clutch master cylinder to use on X83
#13 JoooeOne
  • 88 posts
Posted 19 December 2011 - 08:39 PM
done
#14 JoooeOne
  • 88 posts
Posted 19 December 2011 - 08:44 PM
yup from a celica gts and mk2 clutch pedal and yeah i will be cuting the brake pedal let se what happends
#15 DuaxMachine
    tenacious 7M owner
  • 1,418 posts
Posted 19 December 2011 - 09:15 PM
You can also take it, and bend the arm to make more room,
as long as you trim off the right side so not to creat problems with the 'go' pedal.
One of my X8s:
My eBay items:
#16 Gaijin Smash Wayhoff
  • 167 posts
  • Interests:Everything except x-chassis and JZ engines. Those are gay as AIDS...
Posted 20 December 2011 - 07:41 AM
Mo, do you have a part number by chance?
#17 Kyle
    The Phelan
  • 2,170 posts
Posted 20 December 2011 - 09:08 AM
Gaijin iirc tell them 92 celica gts. I have this in my daily, and had it in my
Melon before it was melon. I think soon I'll try an x7 cmc with homemade remote res.
Why the fuck was this posted in showoffs? It wasn't new info in feb 2010 when it was posted
#18 Andrew
  • 40 posts
  • Interests:Bmx, Toyotas, Metal, Blowing things up, Lighting things on fire, Jumping off things & Having fun.
Posted 20 December 2011 - 03:53 PM
I like this, Definitely taking this into consideration on my next junk yard trip im sick of not having windsheild wipers.
Any pics of the fitment of mk2 clutch pedal?
#19 Demesio
  • 428 posts
Posted 14 January 2012 - 03:09 PM
MK2 with Mk2 pedal, without any spacers on the bottom :/
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
