SERIALNINE SOLID DIFF BUSHINGS !!!!!!
  • You cannot reply to this topic
31 replies to this topic
#1 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 23 September 2009 - 09:00 PM
So basically.. Ya pretty basic.. CNC Solid machined aluminum Differential Bushings to replace the shitty stock sloppy rubber ones..
CONS
These are NOT FOR THE FAINT OF HEART ! ! Recommended for Drifting and Racing only, they are louder than stock. You will hear every bit of drivetrain noise transmitted through to the chassis. . ESPECIALLY if you have the solid sub bushings. . (of course you do right ? wink.gif ) But honestly not that bad. . IF you have interior its not really THAT noticable. . . This being a SOLID link to the chassis, the potential to break drivetrain parts is higher, esp if you are running a 1PCE driveshaft and an UNSPRUNG clutch.. Fortunately cressidas are Burly cars that have big axles, driveshafts and other parts, so I cant see this happening. . (I wouldn't do fully solid engine mounts though as you need SOME give in the drivetrain. )
PROS
They fuckin work awesome. . Like, even THINK of a clutch kick and BOOM instant wheelspin. . its NUTZ,! !.. It'll give you that 100% racecar power transmission. . The throttle modulation is awesome as well, like on/off transitions are DIRECTLY linked to the wheel speed. . SO PRECISE. . . Use these with our new Polyurethane/Billet angine mounts for the FULL benefit. .
They will also help alleviate the cracking subframe issue, due to the diff not being able to move whatsoever and hammer the subframe. .
INSTALLATION
Installation is very straightforward. . but SEMI-DIFFICULT. . The rear ones ARE pressed into the subframe..Im devising the plans to a cheap puller type installer so you dont have to drop the subframe to install, the front one is simple.
PRICE
Production versions will be Anodized Black of course. .
Price is $120 SHIPPED .. (48 stizzates.) Production will start AFTER I have 5 sets on order. .
Paypal is gerard@serialnine.com
G.
G.
#2 Jason
  • 3,722 posts
Posted 23 September 2009 - 09:16 PM
urethane/delrin plans?
im a girl
#3 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 24 September 2009 - 01:19 AM
Non-Metallic plans YES..
But any of the machineable plastics dont really offer any significant sound/vibration advantages over aluminum. . Im still looking though, and I've researched a TON of stuff. . Other problem as well is that most of the hi-tech plastics cost MORE than aluminum, and any urethane type materials costing EVEN MORE than the plastics. .
G.
G.
#4 WhoreMouth_Jr
    Gay Fag!!
  • 970 posts
Posted 24 September 2009 - 03:03 AM
more dopeness!! cant wait for x7 shit!
View PostMo, on 09 October 2011 - 10:03 PM, said:
Go to fucking school before you attempt to breathe this worlds oxygen and roam our planet.
Sheety Blog Attempt
#5 nihonno
  • 269 posts
Posted 24 September 2009 - 05:02 AM
what if you are running the MA70 diff? a bit more for the other side front one?
#6 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 24 September 2009 - 08:08 AM
QUOTE (nihonno @ Sep 24 2009, 01:02 PM) <{POST_SNAPBACK}>
If you're running MA70 diff then I have no idea.. The rear ones you will use.. But the front ones might not fit.. I'll see if i can get one to test . .
G.
G.
#7 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 25 September 2009 - 02:28 AM
QUOTE (WhoreMouth_Jr @ Sep 24 2009, 12:03 PM) <{POST_SNAPBACK}>
X7 subframe/diff bushings done as well. . we JUST finished the SERIALNINE X7. . you guys will shit your pants its so fucking awesome. . Full serialnine everything. .
Coilovers are done as well.. Track testing tommorow, and daily driven after that. . . . They go LOWER THAN FUCK..
Will post up the X7 bushings soon. . Aquiring pics and currently testing. .
G.
G.
#8 WhoreMouth_Jr
    Gay Fag!!
  • 970 posts
Posted 25 September 2009 - 07:30 AM
GOod shit man!!! cant wait!
Sheety Blog Attempt
#9 nihonno
  • 269 posts
Posted 25 September 2009 - 11:29 AM
fitting doesnt seem to be a problem. i made the spacers to fit with 2 stock cressida front diff bushings. just wondering if you could alter the kit for ma70? add a bit for one more bushing.
#10 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 25 September 2009 - 12:25 PM
I could add one for you if you wanted to.. I just wouldn't sell it as a kit until i've actually tested it. .
G.
G.
#11 brian
    I♥1J VVT-i
  • Root Admin
  • 3,572 posts
Posted 27 September 2009 - 10:08 PM
i did the same with my MA70 diff. G, it would be a easy to offer a "MA70 in Cress kit", it would just be 1 extra front.
#12 driftaholic
  • 819 posts
Posted 28 September 2009 - 02:47 PM
x90 plans?
#13 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 28 September 2009 - 04:25 PM
QUOTE (driftaholic @ Sep 28 2009, 10:47 PM) <{POST_SNAPBACK}>
x90 plans?
I already PM'ed you when you first got yoru car.. I Have X90 ones already. . Diff and Subframe.. Both Mats and Ninjabread have the diff and sub bushings.. and Shawley has the sub bushings..
G.
G.
#14 Ninjabread
  • 351 posts
Posted 28 September 2009 - 08:29 PM
Yes, mine should be here this week! So excited!
G's parts are top notch awesome.
QUOTE
Hey I love the taste of the wheel rim to the deep personal! I would certainly feel the wheel of the sports, the man ultimately decides the wheel rim deep balls!
#15 driftaholic
  • 819 posts
Posted 29 September 2009 - 09:42 AM
QUOTE (Gseventythree @ Sep 29 2009, 12:25 AM) <{POST_SNAPBACK}>
G.
oooooooooh thought it was just subframe. I need to lay off the crack it seems. hit ya up soon
#16 knshro
  • 102 posts
  • Country:Japan
Posted 29 September 2009 - 09:57 PM
I want a set.
i also want the subframe bushings.
can i combine orders? and through paypal yes?
give me a total for the subframe bushings, and the diff bushings.
ill paypal you the money.
Thanks
#17 Foompla
  • 1,376 posts
Posted 30 September 2009 - 12:19 PM
QUOTE (Gseventythree @ Sep 25 2009, 11:28 AM) <{POST_SNAPBACK}>
G.
price?
"What's that?"
*music*
#18 brian
    I♥1J VVT-i
  • Root Admin
  • 3,572 posts
Posted 06 October 2009 - 02:55 PM
if you have access to a lift and plan on dropping the fuel tank, do you need to remove the subframe to get the rears out? i was thinking of a slide hammer setup? with the tank out of the way, i would have the room for it.
#19 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 06 October 2009 - 04:37 PM
QUOTE (brian @ Oct 6 2009, 11:55 PM) <{POST_SNAPBACK}>
With the tank out.. no problem.. Its only cuz the tank is in the way that you cannot get a solid angle on them..
G.
G.
#20 brian
    I♥1J VVT-i
  • Root Admin
  • 3,572 posts
Posted 06 October 2009 - 06:54 PM
QUOTE (Gseventythree @ Oct 6 2009, 05:37 PM) <{POST_SNAPBACK}>
G.
perfect! i can drop the tank in like 15 min. i'll order them asap, got a few bills to take care of first.
