SERIALNINE SUBFRAME BUSHINGS/RISERS
  • You cannot reply to this topic
147 replies to this topic
#1 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 05 June 2009 - 07:32 PM
K guys. .so here is the skinny. .
Always looking for ways to improve the handling/precision/stability, and geometry of the X8 chassis, we've developed thes special subframe bushings. When lowering your car, the geometry changes. . When SLAMMING your car. . the geometry changes A LOT. . so much that when you try to align things.. they are too far out of whack, and there is just not enough adjustment. . Well these bushings not only ELMINATE the factory aged slop in the X8 rear end, they help CORRECT the geometry for lowered cars.
SOLID SUBFRAME BUSHINGS/RISERS
I've been running the version 1 ones in my car for like the last event and two months on the road. . And the difference is amazing. . These are a second version of the ones in my car. . The tolerances have been tightened up both on the Body Studs and to the holes in the subframe. . and THEY RAISE UP THE SUBFRAME 10mm for improved geometry and more travel. . Im gonna put them in my car and get the alignment checked to compare the actual difference as far as camber/toe etc. on the rear. .
The pics are pretty hokey. I didn't take any pics with them out cuz they will be Anodized black etc. and i just wanted to show WHAT they do rather than what they look like.. You can see the change though. . just take a look under your car and you'll see right away. . These place the subframe as high as it can practically go without sitting right up against the body. .
The short version is as follows.
-Billet 6061 T6 aluminum Anodized Black
-Gets rid of the slop in the rearend, more direct steering inputs, more predictability at or over the limit, alignment STAYS true under all conditions. (add Bushings or arms for 100% precision)
-Raises the subframe up 10mm for improved geometry and travel Helps get rid of excessive camber and toe, allevieates axles hitting the subframe under full compression.
-VERY TIGHT TOLERANCES TO BOTH THE BODY STUD AND THE SUBFRAME HOLES. . They are NOT press in, but have a zero tolerance fit for absolutely NO movement once installed. * If your car is tweaked or bent in any way you will have to enlarge the holes on the bushings to fit your car.
-ALL support braces and plates fit AS STOCK..
-Easy installation approx. 30min-1 hour depending on your car and your skillz
-They look fucking cool.
-They are SERIALNINE.
Here are some pics. .
This is the REAR UPPER bushing by the swaybar mount. . You can see how little room there is between the subframe and the body. . It actually touches the undercoating in some places around here.
This is the FRONT LOWER bushing..
Closeup of the REAR UPPER GAP.
The following pics are upside down on my test assembly. . dont trip out.
Overall view of the FRONT LOWER part of the subframe. See how close it is to the body.
You can see there IS still a little gap here.
Overall view of the whole subframe mounted up.
This would still be enough gap for the Ebrake cable to pass through and not require re-routing.
**** The tolerances on these are VERY PRECISE, if your car is tweaked or bent in any way you MAY have to ENLARGE the holes in the bushings (drill them out) to fit your car. ****
Special JZXPROJECT intro price. .
All Black Anodized and MAYBE etched with SERIALNINE.
$200 SHIPPED anywhere in the USA. *
* not including the crazy far states you know who you are.
Paypal is gerard@serialnine.com... Please include your JZXP handle and Phone number. .
Any questions ?
G.
G.
#2 5YearSlump
  • 158 posts
Posted 05 June 2009 - 08:14 PM
Very nice!!!
I would gladly pay you on Tuesday for a 2jz swap today..
#3 rayray
  • 2,810 posts
Posted 05 June 2009 - 10:02 PM
very sick stuff g. i really like the idea of raising the subframes. as usual looks to be quality stuff, not just slabs of machined aluminum replacing the stock shit
BellHelmets.com
#4 brian
    I♥1J VVT-i
  • Root Admin
  • 3,572 posts
Posted 05 June 2009 - 11:19 PM
down
#5 Jacob
    lifer
  • 1,595 posts
  • Gender:Not Telling
  • Country:Antarctica
Posted 06 June 2009 - 01:58 AM
I've (one way or another) save/allotted my ching to this upcoming shit.
Question: Sup wit the custom JZ rod?
#6 Keith
    diabeetussss
  • 652 posts
Posted 06 June 2009 - 08:11 AM
Awesome, glad these raise the subframe up as I've been looking at trimming the stock pieces in the meantime. Guess I'll kill that idea.
I would love to have these today as I'm putting the subframe back in. Can you do that? ha...
#7 aphxero
  • 3,246 posts
Posted 06 June 2009 - 09:25 AM
G I love you.
Count me in 100%.
#8 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 06 June 2009 - 09:51 AM
G.
#9 miles
  • 515 posts
  • Interests:drift
Posted 06 June 2009 - 01:02 PM
balllllllllllllin
i was about to try and use s13/z32 subframe collars lol
QUOTE (brian @ Dec 3 2008, 03:05 AM) <{POST_SNAPBACK}>
....rare as sober chick in vegas.
hahahaha
"Yes, it really got suspended for 12 years."
- Me
#10 rayray
  • 2,810 posts
Posted 07 June 2009 - 08:10 AM
front and rear set correct?
BellHelmets.com
#11 Jacob
    lifer
  • 1,595 posts
Posted 07 June 2009 - 08:59 AM
$ sent!
#12 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 07 June 2009 - 09:47 AM
QUOTE (rayray @ Jun 7 2009, 04:10 PM) <{POST_SNAPBACK}>
8 Pieces.. for the rear subframe. . . Replaces all 4 (front and rear) stock bushings.
G.
G.
#13 miles
  • 515 posts
  • Interests:drift
Posted 07 June 2009 - 12:19 PM
im not understanding the "riser" function......any benifit? Roll center maybe?
hahahaha
- Me
#14 N.O. Drifter
  • 753 posts
  • Interests:auto mechanics
Posted 07 June 2009 - 01:05 PM
what will later cost be?
-Carl
#15 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 07 June 2009 - 01:29 PM
QUOTE (miles @ Jun 7 2009, 08:19 PM) <{POST_SNAPBACK}>
Yes, roll center adjustment. . . You're moving EVERY pivot on the subframe HIGHER from the ground, improving things like LCA angle, axle angle, etc.. also removes excessive camber for a given ride height, and allows the car to go lower without bottoming out certain components ie, the axles hit the subframe on REALLY low cars.
QUOTE (N.O. Drifter @ Jun 7 2009, 09:05 PM) <{POST_SNAPBACK}>
Prolly $200 shipped. Not a huge difference.. but its only a sub $200
part. .
G.
G.
#16 Jacob
    lifer
  • 1,595 posts
Posted 07 June 2009 - 05:09 PM
QUOTE (Gseventythree @ Jun 7 2009, 10:29 PM) <{POST_SNAPBACK}>
REALLY low cars.
^meh goal.
#17 rayray
  • 2,810 posts
Posted 07 June 2009 - 07:31 PM
QUOTE (Gseventythree @ Jun 7 2009, 10:47 AM) <{POST_SNAPBACK}>
G.
haha i had to make sure cus that's a bargain price imo
i finally have a stable job atm so i think i'll budget a little and get payment sent soon
BellHelmets.com
#18 Skin
  • 241 posts
Posted 08 June 2009 - 04:09 AM
Nice work ill be down for a set soon
#19 brinkin
  • 383 posts
  • Interests:rev limiters
Posted 08 June 2009 - 12:05 PM
Suspicious Garage
#20 Gseventythree
    serialnine.com
  • 1,557 posts
Posted 08 June 2009 - 12:25 PM
Of course.. We just did a set for JZX90. . the cost will be higher due to being one off. . And I'd need an IS300 her for development. .
If you could get a few other guys to buy as well it'd be cheaper....
G.
G.
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
