this was the one Darren was sellin on here.
well. here it goes....
Swappin out that blown 7m for another NA 7m since i have to drive this sucka down for an inspection since its a WA car.
I'll still be playin with the car till the 1jz is ready to go in.
But the 7m i picked up had some work done. port n' polished head, 3 angle valve job, arp head studs/ hks metal headgasket, new timing belt and water pump. Pretty much picked it up for less than how much all those parts costed. Ha. Also got an rps 12 lb flywheel and a 6 puck clutch, and a stock MA70 supra turbo LSD to use for the meanwhile. Has 3.73 gears but swappin those out for either a 4.1 or 4.3 before it goes in.
The 1jz, still collecting parts for it.
might be pickin up a 2jzgte bottom end and building a 1.5jz
more to come
o and as of today(5/15/09), motor and tranny are out.
