Crank Pulley
24 replies to this topic
#1 Mats
    mr_240sx
  • 743 posts
Posted 05 December 2008 - 09:22 AM
well guys pulled out my engine and turns out my crank puller sheared off.
alot of people are telling me to go ATI. should i spend the money for ATI or should i buy antoher oem new from dealership?
also where is a good place for ATI if i were to go that route.
#2 Keith
    diabeetussss
  • 652 posts
Posted 05 December 2008 - 09:40 AM
Summit is the cheapest from what I've seen for ATI. I'd just get that and be done with it.
#3 Mats
    mr_240sx
  • 743 posts
Posted 05 December 2008 - 09:56 AM
would it be the same from 1JZ and 2 JZ?
#4 Mats
    mr_240sx
  • 743 posts
Posted 05 December 2008 - 09:59 AM
this
http://store.summitracing.com/partdetail.a...mp;autoview=sku
or this?
#5 RubHamusan
    ripgarage.com
  • New Members
  • 357 posts
Posted 05 December 2008 - 10:33 AM
got a 1j u can have just pay shipping
www.RipGarage.com
#6 driftaholic
  • 819 posts
Posted 08 December 2008 - 11:09 PM
1j and 2j are the same. I have a knock off aluminum pulley. a year so far and no problems. but I'm sure a ATI would be better.
only difference is one is under driven. I would recommend the under driven pulley if you are using a 2j pump as they cause cavitation at high rpm but the hydro pump doesn't as bad.
#7 rayray
  • 2,813 posts
Posted 10 December 2008 - 01:53 AM
my buddy has been running a undampened aluminum pulley on a 430whp 1j supra with no issues. the jza80 we have that made 590whp on pump gas has been running an unorthodox undampened pulley all its daily driven life as well.
if you get an ati, they are known to be a BITCH to put on. some people shave it a little to slide on. if you do do that, don't take off too much or the pulley will be too loose.
BellHelmets.com
#8 Keith
    diabeetussss
  • 652 posts
Posted 10 December 2008 - 06:09 AM
From what I've read from some Supra owners, it was suggested to simply heat the pulley up a bit and then it slides right on easily with a few taps from a mallet.
#9 rayray
  • 2,813 posts
Posted 17 December 2008 - 02:53 PM
yes there's that too, but i've tried with a propane torch for 25 min or so with no luck. may be there was corrosion on the crankshaft, i dunno. i haven't attempted to use anything hotter since i was afraid of fucking up the insides of the damper. we DID get one on without heating or shaving, but that took quite a few good long hits with a big 3/4" impact gun.
BellHelmets.com
#10 Bowlsclubboy
  • 233 posts
  • Interests:1jz Cress, Ford Escort Mk2, Ford Falcon XR6 Turbo ute
  • Country:Australia
Posted 20 December 2008 - 06:57 PM
This is what i got..
http://www.rosstuffbond.com.au/metal_jacket.html
Drift car No2 shall be finished some time this century (Hey at least I aint bullshitting ya)
#11 Mats
    mr_240sx
  • 743 posts
Posted 21 December 2008 - 09:09 PM
what did you end up paying for one of them?
#12 TougeCrameryRollinNice
  • 681 posts
  • Country:Nigeria
Posted 21 February 2010 - 12:06 PM
has anyone else noticed that the stock 1jz harmonic balancer pully comes in contact with the stock mx83 sway bar when the car is lifted of the ground. it just barley hits but that can't be good. i would think that if you drove over the right/wrong kind of bump and you get a little air and smack your sway bar into your crank pully and that could be disasterours, right. the stock harmonic balancer on my 1jz vvti looks like its got a larger diameter than the ATI does, a solid non dampend underdriven one sounds like riskey bussiness since "they" say it can cause resonance which can lead to crankshaft failure.... but the price is right on those undampend . i would like to get one of those austrailian ross metal jacket pullies or an ati but damn they expensive.
JDM VIPness
#13 BudgetVIP
  • 1,324 posts
Posted 21 February 2010 - 12:11 PM
That's cause your using x90 mounts reversed. I had the same problem and just switched to X8 mounts. To correct the problem, buy Gerards mounts and move the engine back 5'8's of an inch.
Honky Lips 4 LIFE!!!
#14 TougeCrameryRollinNice
  • 681 posts
  • Country:Nigeria
Posted 21 February 2010 - 12:13 PM
QUOTE (BudgetVIP @ Feb 21 2010, 09:11 PM) <{POST_SNAPBACK}>
i love fast answers... but, i have gerards mounts and they are moved back 5/8ths and im running x81 brackets too. so..... mellow.gif
JDM VIPness
#15 BudgetVIP
  • 1,324 posts
Posted 21 February 2010 - 12:23 PM
is your car a 89-90 or 91-92.
#16 theianmonster
    Little Kid Driving Big Cars!
  • 1,377 posts
Posted 21 February 2010 - 01:22 PM
^^^ That.
Anyways, OEM Toyota is like $500 new or some ungodly price, might as well go ATI man.
POWER SEXY INC. | FACTORY83
#17 CelicaDRIFTER
  • 1,864 posts
Posted 21 February 2010 - 01:29 PM
oem toyota is $299 from driftmotion.
http://store.driftmotion.com/static/i-1jz2...crankpulley.php
i want to get an ATI one, but yeah, pricey. eh.
www.myspace.com/rrabespl
#18 rayray
  • 2,813 posts
Posted 21 February 2010 - 03:00 PM
QUOTE (Bowlsclubboy @ Dec 20 2008, 06:57 PM) <{POST_SNAPBACK}>
QUOTE (Mats @ Dec 21 2008, 09:09 PM) <{POST_SNAPBACK}>
curious as well
BellHelmets.com
#19 Big Fuckin Shooter
  • 606 posts
  • Interests:Umm..hi...I'm here for the gangbang..
Posted 21 February 2010 - 05:29 PM
I have an oem one you can have for cheap as if you want..
Drift like a man. A family man. http://www.serialnine.com
CK
JZX81 MarkII
Tucking tire is fucking fire.
#20 TougeCrameryRollinNice
  • 681 posts
  • Country:Nigeria
Posted 21 February 2010 - 05:40 PM
QUOTE (BudgetVIP @ Feb 21 2010, 09:23 PM) <{POST_SNAPBACK}>
car is an 89. i have a largus sway bar too(not installed yet)... so thats either gonna make the problem worse or better... probably worse:/ this sux.. i guess im not gonna be doing any jumps in my cressida. but i would seriously love to see the pully not touch the sway bar when the wheels are off the ground. it just barely touches but its not cool and i think its because the oem toyota harmonic balancer looks like its the size of a frisbee golf disc. i got in contact with the aussie company , ross. they make the metal jacket ones earlier in this thread... they look sweet.
JDM VIPness
