Apex'i AVC-R
7 replies to this topic
#1 Mats
    mr_240sx
  • 743 posts
Posted 17 August 2008 - 10:20 AM
so yeah... my jzx90 came withh one and everything seems to be good except for the rpm reading is way off. the car idles roughly 800rpm according to the tach and the avcr shows ~160rpm. i looked at the install instructions on the apexi site and it says the jzx90 has 2 rpm signal. now the avcr has only 1 wire. how should it be installed? should the purple wire from the avcr be spliced in 2 and have it touching both rpm signals on the ecu? or do i just need to use one or the other?
#2 Darren
  • New Members
  • 179 posts
Posted 17 August 2008 - 10:25 AM
just ignore the rpm
www.youtube.com/dmcardel
#3 aphxero
  • 3,247 posts
Posted 17 August 2008 - 11:32 AM
go into etc menu then car select.
all better.
#4 Mats
    mr_240sx
  • 743 posts
Posted 17 August 2008 - 12:22 PM
well i read the instructions all of the 70 some pages.... turns out its either rpm readings or injector duty....turns out its wired up to show injector duty so its all good
also car set up is fine. 6 cylenders, and the wire type is the arrow pointing up.
also running 0.9bar should i invest in a SAFC II or is it totally safe when running 91/94 octane?
#5 aphxero
  • 3,247 posts
Posted 17 August 2008 - 01:01 PM
It shoudl be safe. What fuel pump?
#6 Mats
    mr_240sx
  • 743 posts
Posted 17 August 2008 - 01:17 PM
im guessing stock...i dunno. maybe ill just put my wideband from my drift car on there to double check.
#7 Jason
  • 3,723 posts
Posted 25 August 2008 - 08:01 PM
for the rpm signal:
IIRC its either one wire or the other one...NOT both. its the same shit with the safc. both wires carry the rpm signal.
im jzxx83 with jzx90 wiring + safc
#8 Mats
    mr_240sx
  • 743 posts
Posted 25 August 2008 - 08:36 PM
ok tks .... ill check that out in hte morning!
