Fuel system is about 98% done. This is a picture of the bulkhead fitting for fuel return from the fuel surge tank.
turbo and custom manifold installed
(old pic, manifold has been coated and polished since)
fuel pump is a bosch 044 that will be mounted externally inline withh custom surge tank. we are making a fuel return for the fuel system which dumps back into the tank, which originally has no return line.
shot of the surge tank mounted in the cavity above the rear plastic panels. feed is placed to create swirl in the tank. it's fucking thick and sturdy to withhstand debris and abuse. we've had an easy 200lbs hang from it withhout movement.
custom downpipe hacked and welded from a brand new exhaust (tanabe)
as it currently sits as of july-08
all i can say is that space is tight in this engine bay compared to the x8... rest is downhill from here.
BellHelmets.comSpecial helmet deals for JZXP members in 'Private Eyes'
