Toyota X Chassis Workshop Manual and Wiring Guide Motherload
16 replies to this topic
#1 brian
brian
  • Root Admin
  • 4396 posts
  • Powered By:1JZGTE, Big Balls V8, Caffeine, 5VZ-FE
Posted 02 March 2018 - 10:41 AM
Background
These might already be known to most here, but I wanted to create a indexable thread for Google so in the future if someone is looking for these they can find them easier.
So when I was looking for workshop manuals and wiring diagrams for my JZX81 I stumbled across every Japanese scanned workshop manual and wiring diagram for almost every model of X chassis.  This includes the pre-X Mark II Coronas (RT6X) all the way through the JZX100.
Basically if you search on Yahoo Japan Auctions for "jzx配線図" which is "JZX Wiring Diagrams" you will see a bunch of results for CD-ROMS marked with "CD".  These apparently are scans of all of these workshop and wiring manuals being sold for around $30 a volume.  I don't know if it's Toyota who made these, a authorized reseller of Toyota publications or if they're all ripped without permission.  Either way, doing a Google PDF file type search and some Kanji I found these CDs on Ciscokids's server.  I understand that these models were never designed for export, and getting the documents legitimately outside of Japan is very difficult and sometimes impossible.  I've contacted Toyota US about getting Japanese market repair and wiring manuals added to TIS due to the increase of 25 year imports in the US lately.  They basically told me no and to call Toyota in Japan and ask them.  I do believe in right-to-repair and sharing these documents for old out of production cars should not have a big impact financially on the company.  But, if you're from Toyota reading this and want these taken down please contact me ASAP.
Get the manuals
They have tons of good stuff here: http://www.ciscokids.com.au/technical/
Buried here are the manuals in question: http://www.ciscokids...panese manuals/
Now you can pull them all down from there or look at them directly on my Google Drive here: https://drive.google...-Id?usp=sharing
I also backed the zip files up on AWS S3 here:
VOL 2 = T60->X10 1970-1972  https://s3.amazonaws...nuals/VOL 2.zip
VOL 4 = X10->X30 1976-1977 https://s3.amazonaws...nuals/VOL 4.zip
VOL 6 = X60->X70 1980-1984 https://s3.amazonaws...nuals/VOL 6.zip
VOL 7 = X70->X80 1985-1991 https://s3.amazonaws...nuals/VOL 7.zip
VOL 8 = X80->X90 1992-1995 https://s3.amazonaws...nuals/VOL 8.zip
VOL 9 = X90+X70 Wagon 1995-1997 https://s3.amazonaws...nuals/VOL 9.zip
VOL 10 = X100+V20 Wagon 1998-2001 https://s3.amazonaws.com/jzxp/RepairManuals/VOL+10.zip
How to Navigate the manuals
So inside of each VOL folder you will see ichiran.pdf file.  This is the main index PDF which tells you what models the volume covers.  The first page of the index looks like this:
From left to right:
1) Blue is the Description Manual
2) Orange is the Repair Manual
3) Red is the Wiring Manual
4) Green is the Owner's Manual
To navigate the PDFs you have a couple options:
1) Download the volume(s) you want and extract them on your computer then use Adobe Reader to view.  This will allow the hyperlinks built into the ichiran.pdf document to function and made navigating easier.
2) If you're using the Google drive link (probably on your phone) then it's a little harder.  On the far left column is a ID number, that numbers sometimes corresponds the folder names in the VOL directory.  Otherwise you pretty much have to dissect the filename and start manually opening stuff to figure out what is what.
File name breaks down as follows <sequential number>_<manual type>_<chassis>_<covered years>
Manual types are, O = Owners, W=Wiring, R=Repair, I=Information (shows facts about the model, chassis, major components, new features, etc)
Example: 128_W_E-GX70G_1988_9 = Wiring Diagram for Sept/1988 GX70 Wagon
Reading the manuals
OK so now is the hard part, how the hell do you read these if you don't speak Japanese?  Well I use Google Translate on my phone mostly.  Like most Japanese technical writings they use a lot of english for their acronyms, so along with the diagrams/drawings this will help you narrow down your search and give you a good idea of what a particular document's topic is.  Since these are image scans and haven't been OCR'd, built in translation plugins might not work.  So for now I open up Google Translate on my iPhone/Android and use it's live photo translation function.  The live version is a little sketchy sometimes so use the take a photo button at the bottom and highlight with your finger what you need a more precise translation on.
For Google
RT61 RT62 Toyota Mark II wiring manual and repair manual, RX10 RX11 Corona Mark II wiring manual and repair manual, RX30 MX31 MX32 Chaser Mark II wiring manual and repair manual, RX60 RX61 MX61 MX63 Chaser Cresta Mark II wiring manual and repair manual, SX70 LX70 GX70 GX71 MX73 Chaser Cresta Mark II wiring manual and repair manual, YX80 SX80 LX80 GX80 GX81 JZX81 MX81 MX83 Chaser Cresta Mark II wiring manual and repair manual, LX90 SX90 GX90 JZX90 Chaser Cresta Mark II wiring manual and repair manual, SX100 GX100 JZX100 JZX101 JZX105 JZX100W JZX105W Chaser Cresta Mark II wiring manual and repair manual
"Don't bother messaging me if you ugly, cocky, trashy or not in the age range of 31-39" -andreakm26
#2 Foompla
Foompla
  • 1782 posts
Posted 02 March 2018 - 04:46 PM
1.  You'd need someone from Toyota in Japan to send you a cease and desist.
2.  They don't give a shit.
"What's that?"
*music*
#3 brian
brian
  • Root Admin
  • 4396 posts
Posted 02 March 2018 - 06:29 PM
Just covering my ass
#4 Mo
  • 4375 posts
Posted 03 March 2018 - 06:18 PM
Sweet
Fuck you all
#5 slapsticksammy
slapsticksammy
  • 187 posts
Posted 06 March 2018 - 10:28 AM
thanks for sharing
#6 ChriSOL
  • 7039 posts
Posted 06 March 2018 - 02:15 PM
thanks brian, not only for collecting and posting this stuff but also for keeping the doors open here.
#7 LUMBERZACK
LUMBERZACK
  • 376 posts
  • Powered By:7MGE, Dicks
Posted 09 March 2018 - 07:55 AM
Awesome stuff Brian.
#8 brian
brian
  • Root Admin
  • 4396 posts
Posted 17 April 2018 - 08:41 AM
Has to use my own post to wire up my speakers. Rear speaker wire colors are different in JZX81 vs MX83.
311e906b5d15be871e7bb23413e50c443d110f9c
#9 LUMBERZACK
LUMBERZACK
  • 376 posts
Posted 17 April 2018 - 11:01 AM
It's not dead. Just sparsely populated.
#10 Demesio
Demesio
    I♥VTEC
  • 1458 posts
  • Country:China
Posted 17 April 2018 - 12:23 PM
look at the pin numbers to colors.... maybe someone had a misprint?
#11 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2919 posts
Posted 17 April 2018 - 03:04 PM
Looks right to me LH RH just switched positions in the diagram but then again I am colorblind.
I guess your model probably fell on that 2nd color option haha
#12 brian
brian
  • Root Admin
  • 4396 posts
Posted 18 April 2018 - 03:54 PM
yeah the diagrams were flipped and also the positive wiring was different colors.  why i had to look it up at all was because there were four plugs back there.  the additional plugs were used for something else non audio related.
#13 ROBAPHENT
ROBAPHENT
  • 320 posts
  • Country:Australia
Posted 25 April 2018 - 01:58 AM
A lot of manuals of mine have been put up. want to know the kicker, I work for said company that creates this wonderful car :P lol
Anyway they are all like this because i took my old site down to re create it and well work has me building all the dealership websites/applications and it has really killed my mood for building my own.
The missing volumes i do have at home and are going to upload it is just finding the time, if you have any requests let me know and i will see if i can get it via Japan or via work.
i dont like spamming my link or facebook shit but feel free to give facebook a like or send me a PM and i will send you some Ciscokids stickers :)
https://www.facebook.com/CISCOKIDSAU/
http://www.technical.../technical/vid/
these are also video's you might want to watch JZtech is simply a Japanese Hyperrev 1JZ special, in fact not that great but the 2nd Vid is drifting.com how to build a 2JZ special so everything you need to know about building a JZ
CISCOKIDS
The Gentlemen's Club
Midnight Rocker
#14 ROBAPHENT
ROBAPHENT
  • 320 posts
  • Country:Australia
Posted 20 May 2018 - 03:25 PM
Missing CD's VOL 3 and Vol 5 will be up in the next two weeks.
CISCOKIDS
Midnight Rocker
#15 ROBAPHENT
ROBAPHENT
  • 320 posts
  • Country:Australia
Posted 04 June 2018 - 03:45 PM
Will be up by the end of the week.
CISCOKIDS
Midnight Rocker
#16 brian
brian
  • Root Admin
  • 4396 posts
Posted 11 June 2018 - 01:14 PM
woohoo!
#17 Lofty
Lofty
    MOTOBYTE.NET
  • 2167 posts
  • Country:Uganda
Posted 16 June 2018 - 08:19 PM
Thank you all for this.
