What gear oil is best for R154?
  • This topic is locked This topic is locked
52 replies to this topic
#41 Gordo
Gordo
    Resident Grumpy Old Man
  • 6652 posts
Posted 26 September 2013 - 10:44 AM
In a manual trans............
Clean what ?
I have had 50 year old gear boxes appart, and nothing inside but gear oil.
The only thing I have ever get in one is water, and then the trans is shot anyway.
I hope you realize that some of that moose milk will harm the bronze syncros, right ?
That is why some of the GL5 and up gear oils don't work for shit in Toyota boxes.
Besides, I had to find some thread to use that Lord of the Rings facepalm image in :)
Prefixes for 'Gordo'
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#42 4DRSPRA
4DRSPRA
  • 586 posts
  • Powered By:2JZGTE
Posted 26 September 2013 - 11:58 AM
no i was unaware of the issues with toyota transmission and specific oils. i have ran moose milk threw other transmissions and not had an issue and with that retarded think i figured whats good for the gander is good for the goose.
#43 Space Case
Space Case
  • 249 posts
Posted 27 September 2013 - 08:21 PM
Wait- you ran cutting fluid in a transmission? Are you retarded? Why would you use anything with a water emulsification as a pure lubricant? fucking olive oil would work better. Also, it's not just toyota transmissions. Any and all transmission work best with a given kind of gear oil. It's all based on construction. You cant just throw straight weight industrial gear oil in and expect it to work great.
I for one will say that I'm not a huge fan of any redline products. I still use it, because I havnt found anything better for the price. I like motul  gear oil, it retained its shift properties better than my MT90 did in my last W58, but locally its also twice the price. I usually change my gear oil before it gets a chance to lose its additives anyways, since its got particulate in it before it even gets to that point :( hahaha.
Hooray for all the broken toyota transmissions!
RmhHKrS.jpg?1
x7,8,9,110.
#44 4DRSPRA
4DRSPRA
  • 586 posts
  • Powered By:2JZGTE
Posted 27 September 2013 - 08:55 PM
who said cutting fluid. i put marvel mystery oil in with some normal everyday gear oil.
#45 Space Case
Space Case
  • 249 posts
Posted 27 September 2013 - 09:03 PM
moose milk= slang for cutting fluid
RmhHKrS.jpg?1
x7,8,9,110.
#46 4DRSPRA
4DRSPRA
  • 586 posts
  • Powered By:2JZGTE
Posted 27 September 2013 - 09:07 PM
i thought he was talking about marvel mystery oil. my bad.
makes sense now thinking about cutting fluid after mixing it with water
#47 Gordo
Gordo
  • 6652 posts
Posted 23 November 2016 - 12:01 PM
Going to bump an old thread here...
A month or so ago, I had rebuilt a Nissan W71B 5-speed.
Nearly identical to the W58, except it came apart and went back together a lot easier than the W58.
Same style bronze syncros, same size bearings, shafts, shift forks, etc..
Since I had red line MT90 on the shelf, it went in.
Fucking thing shifted like shit !
Drained out the MT90, threw in some Mobil-1 gear lube.
It shifted better, but still not what I would expect out of a fresh rebuild.
Came across a thread on gear lubes & shifting problems that had a bunch of info, but basically saying that the new synthetics or semi-synthetics, although they meet GL-4 requirements, don't get the job done like an old dino lube.
One of the few remaining petroleum gear lubes around is made by CRC, under the Stay-lube name, in SAE85w90, and is sold at NAPA stores.
Picked up some, put it in the trans, and all shifting problems went away.
Guess I would rather change out gear oil once a year, than put up with shifting problems.
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#48 hantavirusx8
hantavirusx8
  • 111 posts
  • Powered By:1JZGTE, Caffeine, Alcohol
Posted 25 November 2016 - 06:05 PM
Good info, I'll stop by Napa and try some of that. My R154 shifts decently on the street with MT90 but trying to grab 3rd while drifting is a gamble
#49 huckersideways
  • 2112 posts
Posted 25 November 2016 - 06:57 PM
So what you're saying is that would probably be good for my shitty CD six speed.
driftwoodgarage
#50 Gordo
Gordo
  • 6652 posts
Posted 25 November 2016 - 08:00 PM
You should also try Shell MTX fluid, I've been hearing good things about it.
What, you can't find MTX ?
It's sold through both GM & Dodge dealers.
GM part number 10953509
Mopar part number 4761526
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#51 AcidTrip
AcidTrip
  • 58 posts
  • Interests:CRESSIDAS & CREAMPIES
  • Powered By:1JZGTE, Caffeine, Alcohol, Dicks
Posted 02 January 2017 - 12:41 PM
redline mt90
INSTAGRAM: CRESSHITA
#52 Okidriftjr
Okidriftjr
    Team Diplomats NO3
  • 889 posts
  • Interests:Why the hell do you think I am here?
  • Country:Iraq
Posted 03 January 2017 - 12:32 PM
I had regular dyno lube in both my w58 and r154. When I switched them out for MT90 both shifted better. I know the zf gear boxes shift like asshole with regular gear oil for the first 1kmiles or so, never asked why.
I keep comming back to toyotas. Guess it's where I belong!
You don't know what JDM is unless you lived there!
Car by panic
Parts by XM
Aero by Lucas
Single handedly keeping the UN alive.
#53 battleaxe
battleaxe
  • 612 posts
  • Gender:Female
Posted 03 January 2017 - 11:03 PM
depends on trans and what they call for as well. which is what gordo was saying. r boxes are that transition years, from old to not so old. i dont have a fsm that tells me what toyota asks for in it.
side note, honda is notorious for this and their transmissions will only run on their oils, honda atf, honda diff fluid, honda synchomesh whatever fluid for their manual transmissions. internet was saying normal motor oil works fine too (its a 10w30? by designation, but motor oil is NO good for the trans) this was the leading cause of a friend of mine nuking 3 transmissions on his ef lol. its meant to get you home if you have none...but really if u have none, you either never change it and it was leaking, or you have a hole in the box..in which case you have minimal choices..
food for thoughts
