Charging issues on stock jzx81
7 replies to this topic
#1 hkp
hkp
  • 312 posts
Posted 15 March 2017 - 11:19 AM
I have a 90 Cresta, stock motor with intake and exhaust, the p.o. had an issue with the car eating alternators, he took the car to a mutual friend who did some shit and installed a fuse, this stopped it from eating alternators, something to do with an exciter wire. P.O. installed powered by max multi gauge that shows Volts, oil temp and pressure, works great, I buy car knowing that car has a parasitic drag on battery, havent had much down time, I just pull negative lead when the car is going to sit overnight and put it back on when i leave for work. Here recently, the car has been acting like a dick head, I get in the car, fire it up, says its charging at 11.1v, run the car for about 5 minutes, then it shoots up to 14.5v and charges at that for awhile and then settles into 13.5v after a little bit of driving. This morning however, it didnt do that, it was charging at 11.1v then progressively got worse until it was "charging" sub 9v with the car slowly dying (not charging). I didnt have time to fuck with it, left in the driveway and grabbed ol reliable (03 RX8 with factory engine and 115,xxx miles) and I drove to work. I don't know shit about the charging circuit on this car so I figured I would ask here, it makes sense, I like being told I'm fucking stupid for not check blah. Any ideas? Also, when looking for parasitic drag, I used my multimeter on amps between neg lead and battery neg, I pulled fuse installed by P.O. to protect charging circuit and it was a substantial drop in battery draw, that would mean that somehow the charging circuit was drawing power when car is in key off position.
#2 Gordo
Gordo
    Resident Grumpy Old Man
  • 6703 posts
Posted 15 March 2017 - 12:05 PM
Stop being a broke-ass Cressida owner, buy an alternator....
Prefixes for 'Gordo'
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#3 hkp
hkp
  • 312 posts
Posted 15 March 2017 - 12:20 PM
This the third alternator, something else is causing this.
#4 Demesio
Demesio
    I♥VTEC
  • 1209 posts
  • Country:China
Posted 15 March 2017 - 12:44 PM
Bad battery could also fuck up your alternator...
#5 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2664 posts
Posted 15 March 2017 - 01:53 PM
Must be that time of the year.  Mine roasted my charge wires last week:
Completely unrelated to you, but I would maybe try big 4 upgrade? (big3 + a ground from housing to block/frame)
#6 nojuan_here
nojuan_here
  • 32 posts
  • Powered By:7MGE
Posted 15 March 2017 - 05:04 PM
Where do you keep getting alternators from? Oreilly's, autozone? Those suck ass. They always seem to fail soon as you install them. Take it off, get it bench tested at your local parts store, get it warrantied or buy a name brand alternator (DENSO makes good reman units btw). The parts stores get theirs reman'd in Mejico, there's a reason they have lifetime warranties. Also check the belt tension.
Second is the parasitic draw still there? Normal draw should be less than 30 milliamps when the car is "asleep".
#7 hkp
hkp
  • 312 posts
Posted 16 March 2017 - 04:44 AM
I'll check amp draw again tonight before I remove the alternator.
#8 Okidriftjr
Okidriftjr
    Team Diplomats NO3
  • 894 posts
  • Interests:Why the hell do you think I am here?
  • Country:Iraq
Posted 20 March 2017 - 10:40 AM
This may help you troubleshoot.
The factory alt plug with three wires contain:
Exciter wire Fed from factory ecu (when metering should be close to battery voltage +-1%)
Charge lamp indicator which is a ground refferance (completes charge lamp circuit when alt is failing)
Sense wire (also should be close to battery voltage +-1%)
The exciter sure litterally turns the alt on and off
The sense wire is voltage feed back to the regulator. A low voltage value here should prompt the alternator to ramp up output current.
I keep comming back to toyotas. Guess it's where I belong!
You don't know what JDM is unless you lived there!
Car by panic
Parts by XM
Aero by Lucas
Single handedly keeping the UN alive.
