Team Running Again Mostly version x.7
755 replies to this topic
#741 Gordo
Gordo
    Resident Grumpy Old Man
  • 7383 posts
Posted 09 June 2018 - 03:14 AM
KAAZ has two different 7.5 LSDs, but neither fit that G housing.
You just need a standard 8" LSD meant for the later cars.
I kind of doubt the Z-car half shaft  flanges fitting. Seem to remember comparing them years ago.
Good luck on the bidding, those are super rare.
And what the seller is saying, is that it has 4.3 gears in it.
Tell me you are not using streeter, like Aaron tried when I found him one.
Prefixes for 'Gordo'
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
Best JZXP statement:
#742 Gordo
Gordo
  • 7383 posts
Posted 09 June 2018 - 03:21 AM
is that an LSD x8 diff or?
That is an open 8" for an X7.
Came out in a late X7 with the first 1JZs.
Never have found anything in parts listing for the car, just like you can't find anything for the Group-A Supra.
Jeez, you people sure don't pay attention, or retain stuff very well.
I've only been pushing these on here for nearly 10 years, every time the subject of the 7.5" power limitations come up.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#743 battleaxe
battleaxe
  • 891 posts
  • Gender:Female
Posted 09 June 2018 - 10:58 PM
ive only been really active on here the past few years. i dont retain EVERYTHING. just reminded me of the cressidas diff, is all. are these 8inch in the same 7.5 housing? i have a kaaz diff for my supras 7.5 and the cressida has a kaaz in it as well for its 8.
if the 8 is in the 7.5 housing but is different to retain the 8, the lack of kaaz diff would make a lot of sense
the reason i asked if it was x8 was because my x8 flanges are 6 bolt like the picture, and the housing sort of looks the same...but then i remembered i have a a6 and x8 and i keep mixing things up between them
#744 Gordo
Gordo
  • 7383 posts
Posted 10 June 2018 - 04:05 AM
Special housing for the X8 to accept the 8" diff.
You can tell it from the standard X8 by the cast cooling fins.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#745 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2881 posts
Posted 13 June 2018 - 01:33 PM
Won that diff for half of what i was willing to pay (I'm sure this link will die in a month or so thats why I initially just linked a picture):
https://page.auction...tion/n268989617
I mostly remember the 8incher coming up from s9 boys, and Robert (who I guess was an s9 boy too) when he was having diff troubles.  But ultimately all of the information about them were assumptions, as nobody ever pulled the trigger.  The best solid information I could find was that toyomods thread where the dude had them setup next to each other, which you still had to infer assumptions from that.
And ya Battleaxe Chris, you can tell the main obvious housing differences from a6/x7 and a7/x8 are the mounting points.   The x8 has the 2 on the rear cover and 1/2 (depending on a7/x8) coming top down in the front.   Where a6/x7 has 8 pickups in the front (4 on top 4 on side) and 2 pickups the rear bar that connects the upper-bit to the car.  the 8in housing is taller for sure (you can see it has all those fins on the bottom gordo pointed out), just an assumption here but I'm guessing all the height goes bellow rather than above the centerline. or least I'm hoping for the sake of pinion angle.  The 8in option was offered in LSD but ya this one specifically is open.  So I'll be on the lookout for a new LSD and a more favorable R&P (3.9 or at least 4.1)
And ya I use Streeter for everything that is larger than a small package.  I still haven't had a single issue with him, other than when he wasn't really shipping aero.  But I usually just ask nicely and he will ship what ever.  Plus he's had a bunch of policy updates over the years. He thinks shipping will be another 200-250 (slightly over the weight limit for boat post.)
In other rear end news,  The machine shop that Rayray's company uses to do the machining had some recent policy changes and no longer does small one off jobs (10 piece min.) So slightly delayed now in that department, but honestly expected because the interaction with the trailing arm fabrication went too smoothly. Something had to counter act that because cressida.
Heres a dog shot and rear brake picture to help alleviate the text wall. Brakes clear all 3 sets I have for the rear just barely (gotta be a few mm tops)
#746 Gordo
Gordo
  • 7383 posts
Posted 13 June 2018 - 02:07 PM
Good job on winning that diff.
Make sure you tell Rue how you did it.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#747 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2881 posts
Posted 25 June 2018 - 10:26 AM
The diff doesn't quite just bolt it.  Guess I didn't look that hard at the comparisons before.   If you look at the top down one, the side-rear mounting pickup is inset compared to the the side-front.  And if you look at the 8" they are more or less at the safe width.  Either way it's not a ton of work, I could just adjust the subframe or trim the diff housing down if it still leaves enough material  The Diff flange is definitely the same as the x8 diff (3.5 inch spacing instead of 3 and hole diameter is slightly larger.)
The 8" Toyota Kaaz has gx71 Turbo listed as a compatible vehicle as well as jzx100, I'm stoked that it can also go into my future car haha.  Now to just decide what ratio I want to run as well as looking into getting the x8/a7 inboard CV ends to fit on the z32 axle shafts.
Haven't done much else other than finally found some wheel studs that work for 1.50 pitch (Toyota) Just gonna put it here for the future because I know I will forget but Doorman 610-254 worked out.  Also the more I look at the the more unlikely being able to use the OEM z32 ebrake drum setup will be.  It's just the way the adapter flanges where designed never even remotely considered them.   Future me problems.
Anyways here's some photos for science:
#748 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2881 posts
Posted 27 July 2018 - 11:37 AM
Diffs in.  Confirmed front 4 holes line up, rear 4 not even close
Ray Ray's Option didn't end up panning out for several reasons.
All I have left is swapping the driveshaft end (which I already have) and weir is making me a pair of CV sends that slide onto the z32 shafts and will be machined to fit x8 output shafts.
So close
#749 Gibbs
Gibbs
  • 1866 posts
Posted 02 August 2018 - 10:41 PM
:wub:  :wub:  :wub:  :wub:  :wub:  :wub:  :wub:
Alexi From Nori Yaro
#750 brian
brian
  • Root Admin
  • 4393 posts
  • Powered By:1JZGTE, Big Balls V8, Caffeine, 5VZ-FE
Posted 03 August 2018 - 08:40 PM
damn can't believe you scored that diff.  so awesome.
"Don't bother messaging me if you ugly, cocky, trashy or not in the age range of 31-39" -andreakm26
#751 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2881 posts
Posted Yesterday, 12:07 PM
^^ Never thought I would see one!
Well finally got this thing all together and took it for a rip with my friends from back home including vampire beats and his freshly minted jz x8.  Had a blast! V8 car as usual zero issues (other than warming up) my car somehow stayed in one piece despite clutch kicks and holding limiter way longer than one should.
The final piece to my rear end puzzle ended up being some CV ends from weir that fit on the z32 axles and mated perfectly to the diff.  They came out really nice and were actually pretty reasonable probably the cheapest part of the whole ordeal haha.  I'll get around to uploading some videos from the event so you all can laugh at my inability to drive sometime this week.
The only real shit thing is the rear won't zero out for toe on one size.  Was around 4 degrees in so I was rocking ~.8 total degrees toe in and I was getting about 3-5 laps per pair of tires.  Even with only going hard 1 lap at a time. I don't know if I was an idiot (most likely the case) and gave them a slightly bent arm to have all the work done to them, or if they welded the one side a little off.  But I'm not sure what I'm gonna do from here. I was thinking if I could have the face that the hub mounts to milled a tiny bit to account for this, but then I was thinking if this is possible also should just mill the camber out too haha.  Rue things getting it rigged up to a machine would be the hardest part cause the arms are so awkward.
Anyways heres the usual photo dump:
I was able to fit 6 wheels and tires in my mini prius, pretty stoked about that (first time these all saw tires mounted in my possession)
Also had my output shafts for my old diff WPC treated for their future owner  :wub:  JZXSEVEN  :wub: Actually really reasonably priced (through rayray) will most likely do that for my current shafts when I eventually rebuild the diff
#752 Gordo
Gordo
  • 7383 posts
Posted Yesterday, 01:26 PM
I'm impressed.....
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#753 Lofty
Lofty
    MOTOBYTE.NET
  • 2134 posts
  • Country:Uganda
Posted Yesterday, 01:27 PM
Awesome man, wished I lived in the PNW
#754 BoristheCat
BoristheCat
  • 209 posts
Posted Yesterday, 06:04 PM
Good shit!!!
I wanna peep it
#755 LUMBERZACK
LUMBERZACK
  • 301 posts
  • Powered By:7MGE, Dicks
Posted Today, 05:10 AM
Hell yeah man, solid progress.
PNW drift events seem so chill. It's so far, but I think it would be cool to someday visit and do a drift event up there.
#756 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2881 posts
Posted Today, 08:31 AM
haha thanks boys! <3
Always welcome to visit Lofty!
And ya the events aren't too bad. The people for the most part are pretty chill, the FC in that shot was some dude I "tandemed" with but had never really met but invited him out anyways.  Super solid guy!  This was a private rental because most of us are terrible at driving.  They let us camp out the night before which was pretty nice as it was about 1.5-2 hours away from us. It was my first time there but once I get the toe and hopefully camber sorted I'd love to go back.
I probably don't have too much going on this weekend Boris, you should swing by!  Uz car also at my place for now
3 user(s) are reading this topic
1 members, 2 guests, 0 anonymous users
